Hi guys,
I have just recently had a new intercooler kit installed, and I thought I would like to share the design with you guys.
It's all CNC mandrel bent one piece aluminium tubes, and I don't think there's anyone else who has this design in Australia.
From the pics you can clearly see that it does not require alot of piping, and there is no need to cut the radiator fan.
All the tubes are replaced, including both the factory compressor inlet and outlet.
The cooler is a light weight tube/fin core, and the end tanks are made from light weight, pressed sheet aluminium.
What do you guys think of the kit??
https://www.sau.com.au/forums/topic/34869-intercooler-kit/
xRHETTx - all up it cost me close to $1,700
The business is performance manufacturing and they're located in Wetherill Park NSW.
I don't think they have a R32 kit at the moment, but they can do it in a reasonable quick time.
You can give them a call on 9756 0495 and ask for Mark
https://www.sau.com.au/forums/topic/34869-intercooler-kit/#findComment-697776
Hi guys,
Hi Nick. Glad you are happy with it :D
Here is a pic of the "Titanium Look" anodized pipes I spoke to you about.
David's pipes are ready to pick up from the anodizers so we will get them tomorrow. He decided to go with purple. We are also picking up the pipes for the EVO, which are red. I can't wait to see how some different colours look on the cars. I am thinking of making up a GTS-T kit in the same colour as shown above.
We could swap yous for the anodized ones you know....... :D
https://www.sau.com.au/forums/topic/34869-intercooler-kit/#findComment-698224
Guys..
Do a search for the Gibson Motor sport R31 race car.
that is very similar design from the throttle body to the cooler.
Actually, the Gibson motor sport bend was even tighther than that and they made some ridiculous power from the RB20 back then..
BOOSTMEISTER from these forums had a similar set up.
I believe that SydneyKID uses this type of setup on the RB20/RB25 motor intercooler pipes..
If I ever get another skyline, that is how I will go about it..
It probably saves about 1 meter of pipe work (maybe a little less) AND, your pipes no longer go over the radiator fan and turbo before it goes in to your engine.
BTW, the Titanium look is brilliant.. best looking pipes I have seen.
https://www.sau.com.au/forums/topic/34869-intercooler-kit/#findComment-698279
Anyone else have a problem with the U bend out of the cooler to the plenum? looks a bit tight to me.
More then 90 degree bends on cooler piping is bad from what ive learnt
What you are saying is partially correct, but all kits are a compromise of many factors. Unless you are going to change the plenum, our kit has less bends than any other kit on the market (as far as we are aware). The bend you are talking about is exactly 160.5 degrees, and eliminates the two 90 degree bends found on most kits. We also change the pipe from the turbo to the inner guard, further reducing the number of bends.
Any way, to cut it short, I agree with what you are saying but I think we have done the best we could to minimise the number of bends, and the lenght of the pipes.
https://www.sau.com.au/forums/topic/34869-intercooler-kit/#findComment-698304
Guys..
Yeah, what he said! :D
Thanks for the compliment on the pipes.
https://www.sau.com.au/forums/topic/34869-intercooler-kit/#findComment-698312
red17.
once it gets under the car, you will require MORE pipes and tighter bends to get to the other side of the cooler on the drivers side.
There are kits that have one outlet on the drivers side of the intercooler come out on the bottom on a sharp angle and have a pipe running along the bottom of the cooler but I'm not sure if it has good flow characteristics at that EXIT point on the drivers side.
https://www.sau.com.au/forums/topic/34869-intercooler-kit/#findComment-699550
The thing we are trying on our intercooling here in the west is to go to the far side(drivers side) of the intercooler first then come through the cooler and exit on the passenger side and it goes over the stock path from there on. thus after the cooler all bends are minimal and soft
https://www.sau.com.au/forums/topic/34869-intercooler-kit/#findComment-699585
RB20LagWagon,
Thats effectively what my cooler (currently being stored in my wardrobe) does. My drivers (inlet) side tank has been modified so that I can run a pipe behind the core back to the stock piping on the passenger side. This requires minimal bends, next to no custom work because its basically a straight bit of pipe with one bend on the end.
GTST. you dont use that end of the core as the EXIT point, you use it as the ENTRY point so that the air has the shortest distance and least amount of time to be heated up on its way into the engine. If you had the end tank modified properly the effect can be minimised. ALOT of japanese kits do this for the RB20/25 motors, so it cant be that bad.
Red17
https://www.sau.com.au/forums/topic/34869-intercooler-kit/#findComment-700188
RB20LagWagon,
Red17
That is the easiest way to do a kit for the GTS-T, but although the kit only needs a minimal amount of piping, the total length of piping once installed is huge!
https://www.sau.com.au/forums/topic/34869-intercooler-kit/#findComment-701491
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
