Hi guys,
I have just recently had a new intercooler kit installed, and I thought I would like to share the design with you guys.
It's all CNC mandrel bent one piece aluminium tubes, and I don't think there's anyone else who has this design in Australia.
From the pics you can clearly see that it does not require alot of piping, and there is no need to cut the radiator fan.
All the tubes are replaced, including both the factory compressor inlet and outlet.
The cooler is a light weight tube/fin core, and the end tanks are made from light weight, pressed sheet aluminium.
What do you guys think of the kit??
https://www.sau.com.au/forums/topic/34869-intercooler-kit/
xRHETTx - all up it cost me close to $1,700
The business is performance manufacturing and they're located in Wetherill Park NSW.
I don't think they have a R32 kit at the moment, but they can do it in a reasonable quick time.
You can give them a call on 9756 0495 and ask for Mark
https://www.sau.com.au/forums/topic/34869-intercooler-kit/#findComment-697776
Hi guys,
Hi Nick. Glad you are happy with it :D
Here is a pic of the "Titanium Look" anodized pipes I spoke to you about.
David's pipes are ready to pick up from the anodizers so we will get them tomorrow. He decided to go with purple. We are also picking up the pipes for the EVO, which are red. I can't wait to see how some different colours look on the cars. I am thinking of making up a GTS-T kit in the same colour as shown above.
We could swap yous for the anodized ones you know....... :D
https://www.sau.com.au/forums/topic/34869-intercooler-kit/#findComment-698224
Guys..
Do a search for the Gibson Motor sport R31 race car.
that is very similar design from the throttle body to the cooler.
Actually, the Gibson motor sport bend was even tighther than that and they made some ridiculous power from the RB20 back then..
BOOSTMEISTER from these forums had a similar set up.
I believe that SydneyKID uses this type of setup on the RB20/RB25 motor intercooler pipes..
If I ever get another skyline, that is how I will go about it..
It probably saves about 1 meter of pipe work (maybe a little less) AND, your pipes no longer go over the radiator fan and turbo before it goes in to your engine.
BTW, the Titanium look is brilliant.. best looking pipes I have seen.
https://www.sau.com.au/forums/topic/34869-intercooler-kit/#findComment-698279
Anyone else have a problem with the U bend out of the cooler to the plenum? looks a bit tight to me.
More then 90 degree bends on cooler piping is bad from what ive learnt
What you are saying is partially correct, but all kits are a compromise of many factors. Unless you are going to change the plenum, our kit has less bends than any other kit on the market (as far as we are aware). The bend you are talking about is exactly 160.5 degrees, and eliminates the two 90 degree bends found on most kits. We also change the pipe from the turbo to the inner guard, further reducing the number of bends.
Any way, to cut it short, I agree with what you are saying but I think we have done the best we could to minimise the number of bends, and the lenght of the pipes.
https://www.sau.com.au/forums/topic/34869-intercooler-kit/#findComment-698304
Guys..
Yeah, what he said! :D
Thanks for the compliment on the pipes.
https://www.sau.com.au/forums/topic/34869-intercooler-kit/#findComment-698312
red17.
once it gets under the car, you will require MORE pipes and tighter bends to get to the other side of the cooler on the drivers side.
There are kits that have one outlet on the drivers side of the intercooler come out on the bottom on a sharp angle and have a pipe running along the bottom of the cooler but I'm not sure if it has good flow characteristics at that EXIT point on the drivers side.
https://www.sau.com.au/forums/topic/34869-intercooler-kit/#findComment-699550
The thing we are trying on our intercooling here in the west is to go to the far side(drivers side) of the intercooler first then come through the cooler and exit on the passenger side and it goes over the stock path from there on. thus after the cooler all bends are minimal and soft
https://www.sau.com.au/forums/topic/34869-intercooler-kit/#findComment-699585
RB20LagWagon,
Thats effectively what my cooler (currently being stored in my wardrobe) does. My drivers (inlet) side tank has been modified so that I can run a pipe behind the core back to the stock piping on the passenger side. This requires minimal bends, next to no custom work because its basically a straight bit of pipe with one bend on the end.
GTST. you dont use that end of the core as the EXIT point, you use it as the ENTRY point so that the air has the shortest distance and least amount of time to be heated up on its way into the engine. If you had the end tank modified properly the effect can be minimised. ALOT of japanese kits do this for the RB20/25 motors, so it cant be that bad.
Red17
https://www.sau.com.au/forums/topic/34869-intercooler-kit/#findComment-700188
RB20LagWagon,
Red17
That is the easiest way to do a kit for the GTS-T, but although the kit only needs a minimal amount of piping, the total length of piping once installed is huge!
https://www.sau.com.au/forums/topic/34869-intercooler-kit/#findComment-701491
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
    • Barrels don't need to be shiny clean. But they are certainly nicer when they are not polluted with years of brake dust, and worse the rotting corpses of the last 17 balance weight sticky pads scattered all around.
    • Yeah, type a special character like ^ or | to initiate the equivalent of the "at"ing for thread links. Although, it might not get any easier to manage. Imagine 30 or 40 threads that kinda match what you want, and the one you want is lost after a long list of useless ones. The magic keyword version I proposed would be a manual effort to set up each case. More of a directed effort from the greybeards to facilitate exposure of useful content. I'm not against the auto complete stuff being considered - maybe por que no los dos? (And where I said "triggered automatically" in my OP, I meant "triggered accidentally". Of course I want it to be automatic!!)
    • Ah yes, fair enough! I was purely thinking about cleaning the spokes and front of the wheel with the mitt. For the barrel the rag on a stick makes more sense. I've tried cleaning the barrels on mine and gave up in frustration. Between brakes being in the way or spokes being in the way and limited space to constantly move the car front and back it was just too annoying. The barrel being as shiny as the rest of the wheel sounds amazing though. At this point I'm not even sure if they have the same surface finish on mine. But I feel inspired now to find out.
