What is the procedure to re-install xenon bulbs on an M35 stagea 2002 series 1, which were remove during compliance for normal bulbs.
Somebody told me I have to remove the wheel guard ( inner guard)and come up from underneath.Is it a cramped fiddly job or is it straight forward?
Arent these lights brighter and therefore safer at night?Why were they fitted from the factory in japan but not allowed in Australia?whats the big deal for Australian authorities?
Edited by samuri
they are removed because there are no automatic height adjustments, and no washers for the headlight units.
anyway, if the ballasts have been removed, youll need to buy new ballasts and burners. if the factory ballasts and wiring is still there, you can just put in new burners.
you need to have a look at them to see what has and hasnt been removed
you need to have a look at them to see what has and hasn't been removed
Thanks zei201.
Only bulbs have been removed.Why are automatic height adjustments, and washers for the headlight units so important,yet the requirement isn't met for Japanese roads.
Obviously on coming glare for other cars is the issue , but surely it would be an issue for Japanese drives as well.
I am curious. why are washers necessary as most cars seen to get by without them.By burners do you mean bulbs?
Edited by samuri
ah one of the many silly ADR's... just like mirrors, fuel fillers etc etc...
It seems Australia knows best for everything, and the rest of the world are wrong with everything.
It's actually, quite funny hearing about vehicle manufacturers refusing to provide cars for ADR crash testing (BMW, Audi, Mercedes) because European standards far exceed our own. I think they just like being unnecessarily officious. That, and they like smashing up other peoples shit...
You will sadly never see a road registered Veyron in Australia because ADR's required TWO vehicles for the authority to completely destroy! At $1.5 mill a POP, they were politely invited to go f##k themselves...
Edited by Daleo
Curiously, I once saw a road registered McLaren F1 driving in Sydney, passed me...quick. One of those things you don't forget in a lifetime!:wub:
I wouldn't have the slightest clue whose it was, how it got here/was registered etc etc. But I don't think 2 of them got smashed! I do see some NZ megacars (Rolls etc) get around, still with kiwi plates on- maybe there is some kind of strange rule about that?
Anyways, back on topic to please Chuckie... Do a search, I swear someone asked the same question. Isn't it either the through the wheel arch/plastic or remove the air box method? Would it be easyier of you removed the Front bar? someone said thats about a 5min job
some cars can be brought in as personal imports and arent subject to RAWS or something like that.
but you have to have owned the car in another country for at least 12 months blah blah
anyway, you may need to remove the airbox on the passenger side, and the radiator overflow bottle on the drivers side to get your hands in there.
they also arent bulbs, they are burners :P
^^ +1 what he said.
its the easiest way IMO.
I once saw a Veyron in Dubai on one of my trips there. window down, guy smoking. hand hanging out the window. I think I cried a little.:(
osted Yesterday, 07:24 PM
isnt removal of the Front bar for headlamp unit removal
I asked the question on dec 20 about removing /replacing xenon globes on m35.. It was easy through the wheel arch on drivers side. passenger side easier through top end.
I tried the passenger side but did not remove the air box (not clear if I must do this or just its a good idea. it was quite awkward and I gave up as I wasn't sure what I was doing with no vision( and a little nervous).
Do I need to remove the air-filter box?
Is the globe replacement a straight swap?
I notice there is an upper and a lower light in the headlamp.( only had my car 10 days)
Where do I make the swap, upper or lower position in the headlamp.
thanks
the xenon is the upper light, yes it is a straight swap. but whatever you do DONT touch the glass of the burner, youll ruin it. an H4 is in the lower position for high-beam and fog light. also dont touch the glass, and yes its a direct swap.
Most manufacturers do not need to submit vehicles to pass ADR, from a crash test and emissions point of view, as they already meet the Euro specs and the ADRs are in the main, based on the Euro regs. The main ADR specific changes are for the child seat mounts and variable dashboard illumination plus all the little pissy bits. They just submit their Euro aproved test results and it gets approved by Canberra..
They are even allowed to leave the ISOFix seat mounts in the cars (Subaru, Audi, BMW, Merc, Land Rover etc.) even though they are technically illegal under ADR.
Some of the ADR documents are copied from Europe even have the Euro (UNECE) numbers in them...
ADR for Xenons
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
