What is the procedure to re-install xenon bulbs on an M35 stagea 2002 series 1, which were remove during compliance for normal bulbs.
Somebody told me I have to remove the wheel guard ( inner guard)and come up from underneath.Is it a cramped fiddly job or is it straight forward?
Arent these lights brighter and therefore safer at night?Why were they fitted from the factory in japan but not allowed in Australia?whats the big deal for Australian authorities?
Edited by samuri
they are removed because there are no automatic height adjustments, and no washers for the headlight units.
anyway, if the ballasts have been removed, youll need to buy new ballasts and burners. if the factory ballasts and wiring is still there, you can just put in new burners.
you need to have a look at them to see what has and hasnt been removed
you need to have a look at them to see what has and hasn't been removed
Thanks zei201.
Only bulbs have been removed.Why are automatic height adjustments, and washers for the headlight units so important,yet the requirement isn't met for Japanese roads.
Obviously on coming glare for other cars is the issue , but surely it would be an issue for Japanese drives as well.
I am curious. why are washers necessary as most cars seen to get by without them.By burners do you mean bulbs?
Edited by samuri
ah one of the many silly ADR's... just like mirrors, fuel fillers etc etc...
It seems Australia knows best for everything, and the rest of the world are wrong with everything.
It's actually, quite funny hearing about vehicle manufacturers refusing to provide cars for ADR crash testing (BMW, Audi, Mercedes) because European standards far exceed our own. I think they just like being unnecessarily officious. That, and they like smashing up other peoples shit...
You will sadly never see a road registered Veyron in Australia because ADR's required TWO vehicles for the authority to completely destroy! At $1.5 mill a POP, they were politely invited to go f##k themselves...
Edited by Daleo
Curiously, I once saw a road registered McLaren F1 driving in Sydney, passed me...quick. One of those things you don't forget in a lifetime!:wub:
I wouldn't have the slightest clue whose it was, how it got here/was registered etc etc. But I don't think 2 of them got smashed! I do see some NZ megacars (Rolls etc) get around, still with kiwi plates on- maybe there is some kind of strange rule about that?
Anyways, back on topic to please Chuckie... Do a search, I swear someone asked the same question. Isn't it either the through the wheel arch/plastic or remove the air box method? Would it be easyier of you removed the Front bar? someone said thats about a 5min job
some cars can be brought in as personal imports and arent subject to RAWS or something like that.
but you have to have owned the car in another country for at least 12 months blah blah
anyway, you may need to remove the airbox on the passenger side, and the radiator overflow bottle on the drivers side to get your hands in there.
they also arent bulbs, they are burners :P
^^ +1 what he said.
its the easiest way IMO.
I once saw a Veyron in Dubai on one of my trips there. window down, guy smoking. hand hanging out the window. I think I cried a little.:(
osted Yesterday, 07:24 PM
isnt removal of the Front bar for headlamp unit removal
I asked the question on dec 20 about removing /replacing xenon globes on m35.. It was easy through the wheel arch on drivers side. passenger side easier through top end.
I tried the passenger side but did not remove the air box (not clear if I must do this or just its a good idea. it was quite awkward and I gave up as I wasn't sure what I was doing with no vision( and a little nervous).
Do I need to remove the air-filter box?
Is the globe replacement a straight swap?
I notice there is an upper and a lower light in the headlamp.( only had my car 10 days)
Where do I make the swap, upper or lower position in the headlamp.
thanks
the xenon is the upper light, yes it is a straight swap. but whatever you do DONT touch the glass of the burner, youll ruin it. an H4 is in the lower position for high-beam and fog light. also dont touch the glass, and yes its a direct swap.
Most manufacturers do not need to submit vehicles to pass ADR, from a crash test and emissions point of view, as they already meet the Euro specs and the ADRs are in the main, based on the Euro regs. The main ADR specific changes are for the child seat mounts and variable dashboard illumination plus all the little pissy bits. They just submit their Euro aproved test results and it gets approved by Canberra..
They are even allowed to leave the ISOFix seat mounts in the cars (Subaru, Audi, BMW, Merc, Land Rover etc.) even though they are technically illegal under ADR.
Some of the ADR documents are copied from Europe even have the Euro (UNECE) numbers in them...
ADR for Xenons
    • A realistic expectattion of how long it has to last also comes down to.... when do you think you will be banned from registering and driving old petrol powered shitters? It's 27 years since that thing was built. It probably rusted out 15 years ago. It was probably repaired and looked OK for another 10. If you do a similarish bodge job now, or perhaps slightly better with some actual rust conversion and glassing, then.... get another 10-15 years out of it, after which you'll only be permitted by the CCP to drive electric cars manufactured in their Shenzen zone anyway.
    • Let me assume that the concern over a manual ECU is that the NeoDET that you have was an auto and has an auto ECU. That ECU will not be a problem, but you WILL have to Nistune it. And you would have to Nistune it even if you had a manual ECU, because the turbo ECUs will shit the bed if they do not have all the things that they were told they have to have, to be happy. The big one being the TCS CU, which you won't have in your car. Anyway, with an auto ECU (which I have running my originally auto NeoDET in an R32) Nistune allows you to put in a Stagea image which doesn't panic about the absent TCS, and allows you to override a whle bunch of other annoyances that would otherwise see the check engine light on 100% of the time. Also, you can't wind up the power very far on the stock NeoDET ECUs without Nistune, because the boost sensor gets in the way. Nistune allows you to push that problem much further up the dial. Do you even have the boost sensor with the engine? Without it, you are SOL and will need an aftermarket ECU (or to find a sensor somewhere, god knows where). I can't tell you what the wiring loom differences are in a 34. But what Duncan said above needs to be considered. When you say "loom", does that include the transmission loom? Because you will need to swap out the auto tranny loom for the equivalent manual loom, and get rid of the neutral/park start interlock (basically hot wire it).
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
