Yup, i'm a p plater... so I own an r33 gts non turbo. :(
So I was wondering what modifications I can make to get some extra power.
If extractors, what brand? how much performance increase will I be looking at??
I think the rb25de is 140kw stock, Could I maybe get this up to 180kw?
Thanks in advance!!!!!
https://www.sau.com.au/forums/topic/348706-na-r33-gts-performance-upgrades/
the 140kw rated power is at the fly wheel, not at the wheels, so if it ever goes on the dyno don't expect it to make that much power. expect closer to 110 to 120kw at the wheels. as for getting a 40kw gain, without major mods (such as rebuilding the engine with bigger cams, higher compression, head work, etc), you won't even get close. a full exhaust, aftermarket ecu and a set of cams might get you 20kw. to be honest though, and a lot of people don't like hearing this, the NA skylines are nothing special in the power department, so there isn't much point trying to get more power out of them. save your money, leave it relatively stock (just do exhaust mods) and then buy a turbo car when you are off your P's.
Ă—
Ă—
