didnt catch it all but on sunrise they were interviewing a guy about a new party he is forming in Vic to take on the cops over their idiotic speed cameras, and antihooning laws etc.
Heres your chance to vote with your feet Or wheels in this case and a huge thumbs up to the guy for making a stand.
https://www.sau.com.au/forums/topic/348711-new-political-party-in-vic/
Get this in NSW and I would quit my job to support him.
Most of the laws are all well and good, yet you cannot lock someone up for doing 200k in a 50 zone when you pursued him for 200k in the 50 zone for over 20 minutes.
P plater, experienced driver, Police officer, race driver, any of the above, if someone walks infront of your car at those speeds there is nothing you can do. Common sense in that someone might not be in the right frame of mind would prevail in all cases.
Not only have I witnessed first hand the exact above scenario, however 2 weeks later have seen the exact same cop pursue a 16yo in a stolen corolla for over an hour TO HIS DEATH.
Enough said, I wont start to harp.
:O
MORE DETAIL REQUIRED!
I didnt catch much of it Ash, But he was a well spoken middle aged guy with enough brains not to be baited by the dumb bitch presenter throwing the word "hoon" at him every 4 seconds.
I like the little I saw and he used the Skaif, D/J, lewis hamilton references to good effect.
Could be a winner.
It's in NSW.... This it?
http://au.tv.yahoo.com/sunrise/video/-/watch/23661319/
Interesting, yet typically pathetic title.
"Backing burnouts and speeding New party supports higher speed limits."
Also typically that they barely show his face talking like most interviews would.
And instead have people illegally misbehaving... Sad.
Yeah, That be it Ash, sorry, i thought it was in Vic. But hey! From little acorns mighty oak trees grow. :thumbsup:
Totally agree :)
Hopefully they gain a lot of ground in NSW, although something like this would undoubtedly work better in Vic given we get raped compared to the NSW people.
Other than appealing to everyone in a car that isn't a stock Camry, what else are they offering? Better roads? Fuel prices? Etc? It's all good and well to support a party with some of your interests at heart, but what are they going to take away in the process?
Well lets give them a chance to have their say and you can make up your mind.
I personally dont care if he doesnt have a plan to save mankind. A party on these lines is never going to govern the state but if they can gather enough support to give car enthusiasts a real voice then I am all for it.
after reading through their website i found this, they will get alot of support for this one.
Law and order• Focus on crimes that have victims
• Policing based on Peel's Principles
• Repeal of 'bikie gang' legislation
• Repeal of terrorism laws
• Police held strictly accountable
I'd just like to see more even speed limits. I'm sick of having to always wonder what speed I should be doing.
It shits me to go from 80 to 40 on a three lane road. Get rid of all the school zone signs that stop me from doing what I should be doing, DRIVING!!!, and better police the people trying to play frogger with themselves. Put crash rails and high fences to stop people crossing where they shouldn't.
And those damn push bikes along Princess Hwy. There's a nice service lane over to the left with a 50 limit that is much safer than this 80 lane you're currently in. And while I'm talking about bicycles. When I was learning the road rules bicycles were meant to do hook turns at intersections. Not play chicken across three lanes and then move to the front and make only two cars follow you through the green arrow!
/rant
  • Like 1
<cut>
More speed signs != more speed limits :)
The government did make a promise to ensure all GPS'es have accurate speed info by a certain year (2012?)....although obviously that doesn't help when your not using one :(
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
