it was mentioned here before but I'm unable to find it searching.
they were near frankston and really cheap to use.
not those decv or whatever they call themselves useless guys.
doesn't have to be this particular one any other suggestions for engineering work?
that aren't excessively strict.
  • Nope 1
https://www.sau.com.au/forums/topic/348720-engineer-in-victoria/
It can be quite hard to find a decent Engineer that wouldn't necessarily be over picky. Have you contacted a few from the Vicroads Web Site on the phone?
They can usually give you a pretty thorough run through on what will be needed on the car for them to certify it.
What sort of modifications are you needing an engineer certificate for? if it is an engine swap that was available in that car from factory they will usually just ask that the same safety components are included which will be pretty much common amongst all engineering places.
Every VASS signatory is strict mate - it's their job to be, and it hinges upon their license.
I've found no VASS engineer any more lenient than another, just the prices are difference.
There is a VASS in Braeside that i used, and a couple of friends have. They are one of the more reasonably priced @ around $600 incl brake test.
Their details can be found on the VicRoads website.
it's just for a carbon hood. yeah i think it was in braeside what's their name?
in the future it will be custom headlights tail lights then power mods.
I'll know their website when i see it I had called them before.
the guys were reasonable over the phone.
I had previously called many vass engineers and all of them wouldn't even contemplate the idea.
these guys were willing if i meet their requirements.
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
