Did a search, found nothing of interest.
Had my Stagea dyno'd and my air fuel ratio was terribad,
Tuner recomended i get a new fuel pump.
Seeing as the car is getting on a bit and i do plan to chase around 400hp-ish,
i want to ask this question
If i buy a Bosch 040 in tank fuel pump, will it fit Link for Fuel pump here
i do not want a walbro, i hear they are temperamental with the voltage.
https://www.sau.com.au/forums/topic/348724-fuel-pump-upgrade/
Just found this: http://www.skylineowners.com/forum/showthread.php?t=144969
Looks like a skyline setup and considering they're based on R33 platforms I'd say it's just like installing a pump on an R33. My advice is to go with an 044 installed with a sock filter (similar to the stock setup) and mounted nice and low in the tank. That what my 32 is running and my mate is has the same in his GTS4 that's supporting nearly 600awhp.
yeah def 044 internal had one set up in my silvia with a modified craddle standard filter when i went 2.2 stroker and had an external in the VLT soooo noisy pinch.gif drove me mad alright for track drag drift car, or other option is to mount under car protected of course good idea to run a good quality in line filter too, but this time trying a walbro know a few guys running them with no probs
the bracket is angled in a S1/S2 stagea so you might have fuel pickup issues when the tank becomes more empty with an 040 due to its open base.
The 044 despite being an external pump is fine in tank but you need a few fittings to make it work ie. sock etc.
A genuine walbro will do the job and is easier to fit than an 040/044.
Nismo stagea pump is direct fit, costs a little more but reduces on labour costs if you paying someone else to fit it.
(All fuel pumps are affected by voltage not just walbros).
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
