if you have someone in the know you will definitely be able to import a vehicle much easier.
The main issue is having someone ( as an agent) to look after the process on the other side. Apart from any stamp duty or import tax there should be no reason why you wouldn't be able to get this done yourself.
What model are you thinking of importing?
something for both grip and drift,
i have owned only skylines since i was young so maybe time for an sr?pinch.gif
although a nice 32 track weapon is always on the cards.
would there be any taxes or fees on our side if its not being used on aus roads?
thanks!
Iron Chef has a special track car coming in...
1996 Toyota Mark II Tourer V Track Car 'Shrek Green' $11,900
60,000km and the rest...
1JZ-GTE 2.5l VVTi Turbo
Tein Coilovers
Defi gauges
ORC Clutch
TRD Strut Brace
Trust Intercooler
Roll Cage
APEXi Power FC Commander & Boost Controller
Final Connexion Bodykit
On ironchefimports.com
doesn't matter what the car is going to be used for the import taxes etc are all the same. the only cost saving is you don't comply it and you don't register it. you still need to pay 10% GST and 5% import duty. along with the other normal AQIS/customs charges, freight charges etc.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
