well i have diagnose that my clutch is not disengaging so im replacing the clutch plate, pressure plate and throw out bearing. but to be sure does reverse gear have a syncro because my reverse grinds bad trying to get it and my other gears are not the smoothest but no grinding problems, so before i spend my money on these parts a want to be sure its not a synchromesh that is buggered. Also I have adjusted my clutch and made sure all hydraulics are working.
Nissan R34 gt (non Turbo)
70000km!!!!
https://www.sau.com.au/forums/topic/348755-does-reverse-gear-have-a-syncro/
reverse does not have a synchro. I have never seen a synchro on a reverse gear. The reason reverse crunches is because it is a straight cut gear, which is also why it whines driving in reverse
RX7's have a synchro in reverse gear.
But to the OP, the clutch won't be your problem. Clamp the line to the slave cylinder and check pressure at the pedal. If the pedal falls away then you could have a master cylinder problem. The adjustment you have made could also be wrong. Remember that too much adjustment can also cause the gears to not engage and will also cause it to crunch in reverse/1st
Cracked pedal box will cause it
Broken pivot ball or throwout fork will cause it
Detached throwout fork retaining spring will cause it
Heavily damaged spigot can cause it
70k on an R34 and you can bet it won't be the clutch plate or cover. Still could be but it's the least likely of all the things. It would have to have a broken spring in the diaphragm or plate for it to not disengage properly
actually it crunches because there's no synchro. you can have a synchro on straight cut gears no problem.
reverse is straight cut because it's easier and cheaper to manufacture (also slightly stronger which means it can be sized smaller and leave more room for the forward gears) which is a sensible choice given you spend 99% of time in the forward gears.
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
    • Yeah, my offer was more to show exactly how rough and ready the rig can be and still be useful. Youtube vids will definitely show cleaner setups. Same concept though.
    • I would guess the seal has gone down at the speedo drive and gearbox oil has crept up the drive cable sheath and fouled the speedo head.
