I always wondered whether this whole process should be checklisted like the SEVs/RAWs compliancing.
ie.
replace fuel filler neck - check
recplace tyres - check
Because what happens at a dyno tune at one workshop will not match another.
I wonder about a few things.
Like do you run with or without silencer?
Do you run 1.5bar high boost and is that fine for the whole boost range? ie. is that relevant if you run only 0.5 bar for everyday? Or is there one run for high and one for low?
Do you test for cold start? Idle performance with aircon?
I wonder if a checklist for the typical car here is warranted?
Typical being PowerFC, maybe mix in a z32, fuel pump, big turbo, EBC etc.
T.
https://www.sau.com.au/forums/topic/34878-what-can-i-expect-in-a-dyno-tune/
Well I can tell you what I like to see.
First, change your plugs, even if they are only a few thousand kays old. If the car is out of tune, it is possible they are covered in carbosn and crap. Cost less than $20 a set. Make sure you have the right plugs before you take the car in.
Idle and cold start - if there are any issues you cannot sort yourself, let them know. If it is cold start,they may need the car overnight, so they can see what is happening when the car is cold.
Light throttle. Seems pretty obvious, but is often overlooked. It doesnt take a heap of time to check the AF ratios at 60, 80, 100, 120 kmh. This can save you a fortune in fuel, as the car can be tuned pretty close to stoich.
Next start tuning power. Usually they will do a prelimnary power run and check AF ratios and timing. Usually, tuning starts at lower boost, then increases as everything is checked safe at that level. Finally, it is worth while getting the tuner to do a final run at lower boost, after the high boost has been sorted, just to check that everything is still ok down low.
Perhaps some people like to do it different, but I have found that there arent alot of places that do their tuning as above, esp the part throttle/cruise work.
Spending a little more time on the dyno to make sure everything is set up right can make a hell of a difference to how the car handles on the road. It is always a good idea to let the dyno operator know you are just after a safe tune, which will ensure they dont push too hard, or tune right on the edge. Tuning too close to the edge can cause problems when you get a poor batch of fuel, change in weather, fouled plugs etc. so IMHO isnt realy worth the worry.
Remeber too, that dynos are a good way to make sure your car is running well, and a guide to guage what difference mods have made to power delivery. If you are after big numbers, just buy a 454 and throw a couple of T88s on it:p
Well, as test on the road can be a good thing. Stuff like making sure the clutch takes up nice and smooth. I have a twin plate unsprung clutch, and adding a bit of fuel in just the right place makes a world of difference to the take up. Generally most of it can be done on a dyno by an experienced tuner. To get someone to do a full road tune (I did it once, took 2 days) is a very costly exercise, and debatable whether it is worth the extra.
The biggest difference IMHO is getting an experienced tuner, who takes the time needed to do the job right instead of rushing to try and make a quick buck.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
