Hey guys,
i got some hid's for chrissy put them in today they work awesome....... except my tail light now dont work and either does the dash lights (speed, rev, fuel etc)
any ideas what it may be cheers cam.
I would be checking all fuse`s
https://www.sau.com.au/forums/topic/348786-hid-problems/#findComment-5606422
Is it possible for you to take a photo of this install so we can get a further understanding as to what has been done and what setup you have.. Always the more info you can provide and show the easier and faster it can be solved.
Cheers.
https://www.sau.com.au/forums/topic/348786-hid-problems/#findComment-5611276
yeah the HID's are fairly plug and play... pull the fuses out and check they are def ok
other than that, there's only 2 wires you really need to connect... sooo there isn't really much room for error :S
https://www.sau.com.au/forums/topic/348786-hid-problems/#findComment-5620378
Checking the fuses with a test light doesnt work, the test light still lights up. Psychically pull them out and check them one by one
Oh yeah, I just remembered thats what happened with fiance's HID's. It blew one of the fuses and the test light still showed up ok. I pulled the fuses out and one was epic busted...
So don't always trust the test light :P
https://www.sau.com.au/forums/topic/348786-hid-problems/#findComment-5625704
Thread hijack, but I also have a problem with lights.
My right headlight, just refuses to work atm. We're talking hi beams, low beams, parkers. Nothing. Worked fine until a few nights ago when my low beam bulb was about to die. Wiggled it about a bit to get it to work so I could drive home, and it died, and now nothing works. I imagine a fuse is blown, but even getting a mate to translate my jap fuse box revealed nothing about why only one side was out. Anybody care to shed any light on this?
https://www.sau.com.au/forums/topic/348786-hid-problems/#findComment-5630291
    • I would hope so. I worry that it also might depend on whether the person working on the claim has had a good day or not. I could imagine that for example modified brakes would be an easy thing to point to for affecting the outcome of an accident. I don't know. I will keep paying my premium and hope for the best. But at the same time keep safe distances, drive defensively and avoid dickhead P-platers in lifted utes
    • I was just working on the assumption that a cammed V8 is significantly less polluty than a Japanese I6 turbo was at the way they tested it in an IM240. Perhaps I'm wrong! Perhaps cutting one of the readings I got in half is a tall order. I don't know too many people who actually got their cars emission tested with a RB to really compare the data.
    • I thought it was just if “the modification effected/caused the incident”
    • Ok, good to know. I have open loop I think, I forgot which ones which but I am running the o2 sensor, brand new and I got a new boost solenoid because my last one was faulty and overboosting by a lot, but it's still technically overboosting. Haven't really bothered to hunt it down as I don't send it hard regularly.
    • You should not be able to see much smoke behind you if the mixtures are good - for ~13-14 psi anyway. It's not like you need to be running hell rich for only that much boost/load. Your tune might be a tad too rich. The tuner might have done that because they like to run a lot of timing. It's impossible to know what's going on from here. It won't be the actuator. It won't be the MAP sensor. Regardless of if by "MAP sensor" you mean either the Neo ECU's boost sensor (which is literally only that, a boost sensor so that the ECU knows a) that it's achieving boost, and b) that it is not overboosting) or you mean the dash gauge's MAP sensor (because it can't have any effect at all), or you mean the boost controller's MAP sensor (because it is very unlikely that it is running in closed loop, and so it is effectively just used to know when the pressure goes positive and so you can see the boost on the display, for the most part).
