Hey guys,
i got some hid's for chrissy put them in today they work awesome....... except my tail light now dont work and either does the dash lights (speed, rev, fuel etc)
any ideas what it may be cheers cam.
I would be checking all fuse`s
https://www.sau.com.au/forums/topic/348786-hid-problems/#findComment-5606422
Is it possible for you to take a photo of this install so we can get a further understanding as to what has been done and what setup you have.. Always the more info you can provide and show the easier and faster it can be solved.
Cheers.
https://www.sau.com.au/forums/topic/348786-hid-problems/#findComment-5611276
yeah the HID's are fairly plug and play... pull the fuses out and check they are def ok
other than that, there's only 2 wires you really need to connect... sooo there isn't really much room for error :S
https://www.sau.com.au/forums/topic/348786-hid-problems/#findComment-5620378
Checking the fuses with a test light doesnt work, the test light still lights up. Psychically pull them out and check them one by one
Oh yeah, I just remembered thats what happened with fiance's HID's. It blew one of the fuses and the test light still showed up ok. I pulled the fuses out and one was epic busted...
So don't always trust the test light :P
https://www.sau.com.au/forums/topic/348786-hid-problems/#findComment-5625704
Thread hijack, but I also have a problem with lights.
My right headlight, just refuses to work atm. We're talking hi beams, low beams, parkers. Nothing. Worked fine until a few nights ago when my low beam bulb was about to die. Wiggled it about a bit to get it to work so I could drive home, and it died, and now nothing works. I imagine a fuse is blown, but even getting a mate to translate my jap fuse box revealed nothing about why only one side was out. Anybody care to shed any light on this?
https://www.sau.com.au/forums/topic/348786-hid-problems/#findComment-5630291
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
