Nissan Skyline, R33 Series II, 1996
Interior still A1 seats all good no interior been stripped,
Front bar not on photos but will go in sale
Ok lots and lots of mods forgive me if i forget some below"
-Aftermarfket forward facing plenum custom
-Z32 Air flow meter
-HKS gate with screamer
-Slotted front roters with new rear bendix brakes
-Flared and rolled rear guards
-Big FMIC custom stainless piping
-HKS coil overs
-3" exhaust system
- Access tuned Apexi power FC with hand controller
- Momo aftermarket racing wheel
-Apexi power intake air pod
-Cusco and HKS sway bars front and rear
-Aftermarket oil catch can
-Built RB25 motor done hardly any k's
-Bosch 040 fuel pump
-Greddy dual stage boost controller
-HKS turbo timer and secondary boost guage
-Garrett aftermarket huge will update type later
-HKS bov
-Bayside blue with fibre glass kit
-Heavy duty clutch
-New 25 Gearbox
-550 Nismo injectors and fuel rail
-18" Wheels loads of dish
-Nismo clear side indicators
-Tuned by Boostworx running 271.5rwkw on 14psi safe range has heaps more in reserve
-New Bendix brakes as of 27/12/10
Contact me on 0431-388-718 or pm me
Car is in Adelaide can be sent to all states
It is defected for to low to loud and the top mount turbo didn't help haha
NO LOW BALLERS!
Edited by sus34
https://www.sau.com.au/forums/topic/348813-r33-series-ii-899000-heaps-of-fruit/
Yeah but I wouldnt buy a car interstate without seeing it in person, just a big hassle... and I'd have to get this blueslipped etc, i.e returning it to stock for it to pass.
Im spewing though, such a nice car, value for money
goodluck
Edited by TONTON
only thing coppers could pick is the topmount and if it has coilovers , borrow a standard lowmoint setup and dummy the intercooler piping and then chuck it straight back on still a mega bargain!!!
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
