Ok before anyone says it, i've searched and after SAU upgraded, it can only go back so far so i couldn't find much info and i've checked the RB26 dyno thread but there wasn't many results + i am after people's personal experience with them.
my stock R34 GTR turbo seals are gone and need to be replaced. I was looking at finding a 2nd hand pair of R34 gtr units to replace but stumbled across these N1 units on ebay.
http://cgi.ebay.com.au/Rebuilt-GTR-Turbos-Kit-N1-Steel-CHANGEOVER-RB26-R32-R34-/120540442186?pt=AU_Car_Parts_Accessories&hash=item1c10c52e4a#ht_696wt_905
Seller states that they are rebuilt R33 GTR turbos with steel wheels & 360 degree thrust bearings + they give warranty also.
**Has anyone purchased the rebuilt N1 turbos off ebay??**
How laggy are the N1 turbos over stock GTR turbos?
Does anyone have any dyno graphs to show when it would hit full boost (say 1-1.4bar)?
I just want to see whether or not they're heaps laggy or just slightly laggier then stock units.
i am not after overall power and prefer something with near stock response.
I have all the usual upgrades (bigger injectors, ecu & map sensor)
Any help much appreciated.
https://www.sau.com.au/forums/topic/348826-n1-turbo-queries/
R34 GTR stockers are ball bearing, R32 & R33 GTR stockers are journal/thrust bearing not to mention an outdated design compared to the R34 stockers, they will be laggy as.. and at the price that seller is asking, do yourself a favor and buy a pair of genuine -7's
And remember these are "N1 spec" not actually N1 turbos at all, so they're possibly worse than genuine N1 turbos
R34 N1 are identical to Garrett -7s. Positive pressure at 2000rpm, response is close enough to stock. There not laggy/doughy unless there's something wrong with your car....Here's mine;
Woah! 300kW at 16psi? Thats very nice. I thought that figure will only come in at around 20psi. The 34 N1s are definitely better.
lets get some facts straight here
ball bearing turbos do not spool faster , journal turbos are floating on oil
The good thing about journal bearing turbos is they can be rebuilt. Try that with your ball bearing turbos
N1 turbos are not laggy if you find they are then look at your tuner not at your turbos
Just because some one had a mates cousins dad with a bad N1 turbo tune it seems to have become an internet rule that N1 as laggy.
And to be honest with the crap that garret has been delivering of late who would want to buy new turbos from them
Edited by waxracing
R33/32 GTR N1 Turbos ARE LAGGY.
To say they are not shows that it is you who knows not what he is talking about. They are effectively a 20yr old design now.
R34 N1 carry the updated wheels, and cartridge from Garrett that was done for the R34 only. No tuner can magically make old technology as good as new technology.
There are a few results inthe dyno thread of the older ones, andusers have posted plenty about that fact for a long time given some people must use them due to racing class restriction.
It shows you have a bad tune, I have been a few cars with n1 turbos that are not laggy. All turbos up to till the borg warner efr are old technology.
I'm not interested in an internet flaming war as to whose cousin had lag issues etc.
"Laggy" is in the eye for the beholder, so you guys should probably avoid that term. Can we at least agree that 32/33 N1s are laggier than 34 N1s, and therefore if you were looking at new turbos you'd only go for the 32/33s if you had to due to competition rules?
True. But I'd say anything below 3000rpm shouldnt be considered laggy at all.
positive pressure below 3000rpm doesnt mean the turbo isnt laggy, its also how long it takes to ramp up to full boost from then,
my car has bolt on N1's and they are really responsive compared to a mates N1 GTR with factory N1's and poncams,
i have tuned both cars and mine will make full boost 1000rpm earlier, have tried cam gears in all different positions and other tricks but his N1's are Laggy.
so... some N1's are laggier than others,
They give you the speed graph because it's accurate, whereas RPM may not be as they have to "configure" it with the right values to show RPM correctly. This means working out rolling diameter of the wheels and diff ratio exactly.
I had the old N1 (bush bearing) turbos. take it from me, they are laggy, i have a dyno sheet in the RB26 thread -> http://www.skylinesaustralia.com/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page__view__findpost__p__5112467
The engine was thrown in my car with these turbo's I bought them as stock ones, so i didn't question it.. we thought we had issues with the boost controller and a restrictive exhaust. It turned out they were the old Group A turbos you are describing.
They would start to spin up at any speed, you could hear them. But really the car wouldn't come alive until around 7psi, they're great for big cheap power and you can put a tonne of boost through them like the old gibson r32 did (2bar+??).
I have since sold them and gone to stock turbos. next purchase will be a medium sized single or some R34 N1's.. as most of my decisions are based on cost Vs performance.
I had the old N1 (bush bearing) turbos. take it from me, they are laggy, i have a dyno sheet in the RB26 thread -> http://www.skylinesa...ost__p__5112467
N1 turbos and group A turbos are not the same thing. The group A turbos are bigger
No you dont, its this simple, hold speed at 100km/h, load up the dynoto say 40-50rwkw, look at ecu/hand controller to see accurate rpm, enter into dyno. It takes about 30 seconds, or of you have the pickup option on th edyno it takes about 10 seconds to select rpm as the scale instead of km/h
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
    • Assuming that they will come off without damage at all.... i would have thought just pull straight up off the spindle with a something or other than can reach underneath. Have you searched for youtube vids of people doing similar on R34s or any other Nissan from the same vintage? They should be the same technique, in all likelihhood.
    • Keeping in mind that sandblasting is really aggressive on softer metals like cast alloy, and you can do damage that you might regret. For trash wheels, not a problem. For wheels with value/scarcity issues, etc.... perhaps a less aggressive media is a better choice?
    • Don't get all high and mighty. Experienced spanner wielders know exactly what effort is required to release an Oof.
