FOR SALE!! $12,000
  • Brand New PPG 5 Speed Straight Cut Dog Box suit nissan GTR 32/33
  • Never been used (has oil in the gearbox)
  • Full gearbox Bearing kit installed.
  • Also comes with Billet Main Shaft.
  • This Gearbox Features the best of everything PPG has to offer.
  • Fully Assembled by one of the very best Mark Jacobsen from Godzilla Motorsports.
  • It is the full gearbox less the Transfercase.
  • Also has Gearstick which is not shown in the photos.
    One of PPG's most infamous gearsets, this exact product powered Theo Woolett's 8 second R32 GTR to the title of fastest H pattern gearbox powered GTR in the world. Able to withstand over 1000 engine horsepower, this set has endured punishing abuse in all corners of the globe and has an unrivalled reputation as a near bulletproof drivetrain solution for those not wanting to fit a costly and sometimes less reliable sequential gearbox to their GTR .
A direct fitment product that comes complete with 1-2 and 3-4 billet selector forks.
PART NUMBER-PPG5SPSTRGTR
APPLICATION-Nissan Skyline
R32/R33 5 Speed
Engine-RB26
Ratios: 2.621 / 1.637 / 1.240 / 1.000 / 0.839
Horsepower Rating: 1000 hp
Notes-PPG manufactures a solid billet mainshaft and also the 5/Rev Selector Rod that is recommended for vehicles exceeding 900hp
Gearbox has been cleaned since these photos and looks like new..
Also have a brand new npc clutch to be sold with gearbox to match the big billet shaft. Clutch is rated well over a 1000hp as is the gearbox,
Yea mate the billet shaft is alot bigger in diameter than the standard shaft. It is the same as a chevy truck spline. So thats why i will offer to sell the clutch as well.
    • 2 things. 1. If you're going to buy a ball joint puller/pusher tool that is not advertised as being for the purpose you intend to use it for, then it is up to you to make sure, either before you buy, or after you first try (and possibly fail) that it will work for that task. 2. WTF? Putting HICAS balljoints back into a car implies retaining HICAS, which is just....dumb. HICAS can lick my left one.
    • After cleaning the contacts in the remote, if it has rubber carbon pads on the buttons, give them a little wipe with a 2B pencil to add some fresh carbon back. Just a little wipe. Not too much.
    • The one door lock not working intermittently sounds odd. But for the other issues I'd suggest to clean the contacts and everything on the little board inside the fob. I had the same issue with unlock working but not lock, and that solved it. It brings such a quality of life change to be able to lock and unlock the car like a normal person
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
