Hey guys Im new here and new to nissans the names Chris and iv run in to abit of a problem with my car not turning on (R33 GTR 1995) so ill start from the beginning....... and let me get it out of the way for you now and let me say im an IDIOT!
so I was trying to install a turbo timer I got a HKS one with a plug in type loom so I pulled off all the trim bits to get to the ignition barrel and unpluged the plug that goes to it. I then found that the plug on the HKS loom was the wrong size but the pin lay out was the same so me not thinking and being a f-ing idiot and not thinking about disconnecting the battery I pulled out the pins from the HKS loom and pluged them in to the ignition barrel plug 2 of the pins touched and a small puff of smoke come out ( It was then I rememberd about the battery that I didnt unplug :/ ) so i removed HKS loom pins from the stock plug and pluged it back in to the ignition barrel tryed to turn the key and nothing! no lights on the dash nothing! I looked thru all the fuses and non of them are blown I looked at the fues box in the engine bay and the one thats in the dash.
do any of you have any ideas? am im missing a fuse box? is there a ignition fues thats greater than 10Amp? is there like a 30Amp fuse that im missing or like a relay? do any of you know what the blue relays are for the ones next to the fuses ( the fuse box in the dash) ? do you think i stuffed the ECU?!?
iv only had the car for 2 weeks and love it to bits i feel like such a fool :(
Thanks, Chris.
Edited by Mr Chris
https://www.sau.com.au/forums/topic/348846-please-help-car-not-turning-on/
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
