i would almost assume that all 1/10 plastic rc bodies would fit, just gotta give them a bit of love with a drill to get them to sit right!
but with KE70 being the bastard cousin of the AE86, it seems there arent 70 shells, only 86's
  • 4 weeks later...
I have a Losi 8IGHT-E 2.0. I have a 2400kv motor in it with a few other mods. In it's current setup it's way to fast for track racing (well for me to drive anyway) hits over 100kph. Lots of fun! I can drag my R32 GTR off with it no worries ;-)
If i'm about i'd love to catch up with some ppl for a bit of fun. Some of the 1/5 scale monsters must be awesome to see...
Jeff
  • 4 months later...
  • 1 month later...
I've recently inherited a couple of nitro cars, can't find any model or branding on them.
Does anyone know how to reset the needles? I don't have a manual or anything for them.
Can get them both idling but stall once you hit the throttle, one spits heaps of fuel out the exhaust so I try leaning it out bit by bit but the shit of a thing keeps spitting fuel until it just refuses to run and I have to richen it up again!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
