jzz30/r154, just put a new clutch in it last week. was an 'extreme' clutch with lightweight cromoly flywheel. direct clutch rebuild with carbonic plates and increased clamping pressure. was setting up the two step, but had it all pretty tame. did one launch at 3000rpm, one at 3500, and two at 4000, very little slipping of the clutch though, (first 3 attempts bogged down, last one was smooth but nothing too agressive) and there was probly 5 mins of very sedate driving between each test launch. on the last one, i went for the clutch and couldnt grab second, clutch would not dissengage.
fair enough, so we went and got a bottle of fluid and bled the thing for an hour, can get it to dissengage now... sometimes. its random, goes good, then shit again, bled it heaps already. thats one problem.
problem two, the c*nt is realllllyyyy f*cking noisy now, especially in reverse. makes a hell grinding noise, and rattles like a twin plate when dissengaged
did i overheat it and weld it to the flywheel? (heard of this problemon high hp supras in the US, not sure if 'carbonic' can be welded to chromoly) when clutches 'weld' them selves to flywheels, do they normally break off themselves when they cool down? why has it gone hell noisy all of a sudden?
thanks, and happy new year guys :)
Ben
sad to say but thats a common problem with extreme clutches.. however its usually the brassbuttons that do it not the carbotics. either way i have a nice pile of failed extreme clutches sitting in my shed from various customers that tell another story.
thats the thing, while it was in the last car (current owners brother) it never had an issue. we pulled it out of his brothers car and i said its low and told him to get it rebuilt, and being that the current owner is chasing more power, we sent it to direct clutch for a rebuild, and it was them that rebuilt it with the carbonetic pads...
been driving it more today, it had a serious twin plate rattle (its only a single plate clutch though) which has since subsided, engaging issue is semi-sorted and livable. only problem is the grinding and biting now.
what actually does this simon? did i overheat it and sieze it to the flywheel?
yeah i took a good look over it before i put it in, springs actually seemed to be pretty secure in there, was worried they may have fallen out now tho. it does explain the biting and rattle :( although now the rattle has mostly gone away, its more of a grinding noise now, although even that has improved vastly with more driving. just gonna keep driving it for a bit and see what happens :)
thanks for the help
is it definately seized to the flywheel and not a hydraulic problem? put it in first, foot on clutch, and rock the car back and forward. should break it free. or put it in 4th, clutch in and just smash it on the starter a few times lol
this happened to me a dozen times with an extreme clutch :down: welded clutch plate to flywheel, push it out onto the street, start it in first (it will obviously jump forward and go but it will start) put your foot on the clutch take it up into the boost zone and nail it.. as it comes on boost it will break free, worked every time for me.. always leaves a bit of ruff stuff on the flywheel but that smooths out after a short drive with a couple quiet take offs slipping the clutch a little. when I took the out it had chunks missing from the carbonic pads obviously broken off from welding. good luck with clutch
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
