Item Summary: R33 Garage cleanout Seats, Interior parts and Coilovers
Condition: Used
Reason for Selling: Dont need anymore
Asking Price: 600
Delivery Methods: PickUp
Contact Info: Will 0422886721
Extra Information:
Garage cleanout time,
I have for sale a R33 Skyline GTST interior containing Front and Rear seats in mint condition including door cards.
I bought these to put in my car but reconsidered and would rather the cash to put back into my car.
Price is $500.00
Also have glove box, centre console(no gear surround), carpet, roof lining, rear seatbelts with moulding etc. If interested let me know and well sort out a price for these.
Also have for sale a set of HKS Coilovers (wound up to maximum height for legalities lol). They have been great, car has done a touch under 20k with them (Were bought new by previous owner). As I am changing my car to drag set up I don't need them anymore.
They are still in car so I can take you for a drive and show you how well they handle. My friend had TEINS in his and said these ride alot better than his did. The picture posted is of coilovers I found on the net of the same colour. I believe they are hypermax dragger coilovers. No leaking or bush damage that I am aware of.
Price is $600.00 for the coilovers.
Item Summary: 18 inch slicks for sale x 4 Michellin and Dunlop Slicks for sale
Condition: Used
Reason for Selling: Garage clearance
I also have some slicks that are just sitting there.
2 x Dunlop Slicks 230/640 R 18's (230 width). I used these at Powercruise 2009 and they hooked up well for the width. NOTE ** due to dropping pressure in them for better grip and not using softener they have some cracking on the side wall. $100 for the two
2 x Michelin Porsche Cup 24/64 - 18 (240 width). They are in great condition and give great grip. They are $150 for the pair which I think is a good price.
I used of the same tyres on the rear of my car at powercruise 2010.
Both have been stored for a while so are a little hard but get some softener and I am sure they will soften up beautifully.post-19906-0-12896500-1293849505_thumb.jpg
If interested in any of the above please PM me or call Will on 0422886721
https://www.sau.com.au/forums/topic/348866-r33-skyline-garage-cleanout/
Gday,
For a s2 r33 gtst; I'm after A pillar trims (both sides), rear wiper motor, rear washer jet, boot lock clip, floor carpet, washer bottle and both pumps, horn, centre/wing brake light, airbox and snorkel. Please let us know if available and price.
thanks, Ben.
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
    • I’ll have more of a look into Recaros over the weekend. It’s taken me 2 days to figure out which Bride seats suit my application haha.
    • I am aware of their presence, but the product page looked like that conversion will eliminate the AWD capability. Fact remains it's kind of a hassle to send my oil sump halfway around the world and buying an extra one is expensive and unnecessary. Before I go hat route I'd explore more local options.    Would you recommend I just pull the engine and renew as many things as possible since I'm already having problems with some leaks? Would have to get an engine crane first though.
    • Are there any indicators that the vehicle is in limp mode?  Any dash light, or something.  Or is it just lack of acceleration?
