Item Summary: R33 Garage cleanout Seats, Interior parts and Coilovers
Condition: Used
Reason for Selling: Dont need anymore
Asking Price: 600
Delivery Methods: PickUp
Contact Info: Will 0422886721
Extra Information:
Garage cleanout time,
I have for sale a R33 Skyline GTST interior containing Front and Rear seats in mint condition including door cards.
I bought these to put in my car but reconsidered and would rather the cash to put back into my car.
Price is $500.00
Also have glove box, centre console(no gear surround), carpet, roof lining, rear seatbelts with moulding etc. If interested let me know and well sort out a price for these.
Also have for sale a set of HKS Coilovers (wound up to maximum height for legalities lol). They have been great, car has done a touch under 20k with them (Were bought new by previous owner). As I am changing my car to drag set up I don't need them anymore.
They are still in car so I can take you for a drive and show you how well they handle. My friend had TEINS in his and said these ride alot better than his did. The picture posted is of coilovers I found on the net of the same colour. I believe they are hypermax dragger coilovers. No leaking or bush damage that I am aware of.
Price is $600.00 for the coilovers.
Item Summary: 18 inch slicks for sale x 4 Michellin and Dunlop Slicks for sale
Condition: Used
Reason for Selling: Garage clearance
I also have some slicks that are just sitting there.
2 x Dunlop Slicks 230/640 R 18's (230 width). I used these at Powercruise 2009 and they hooked up well for the width. NOTE ** due to dropping pressure in them for better grip and not using softener they have some cracking on the side wall. $100 for the two
2 x Michelin Porsche Cup 24/64 - 18 (240 width). They are in great condition and give great grip. They are $150 for the pair which I think is a good price.
I used of the same tyres on the rear of my car at powercruise 2010.
Both have been stored for a while so are a little hard but get some softener and I am sure they will soften up beautifully.post-19906-0-12896500-1293849505_thumb.jpg
If interested in any of the above please PM me or call Will on 0422886721
https://www.sau.com.au/forums/topic/348866-r33-skyline-garage-cleanout/
Gday,
For a s2 r33 gtst; I'm after A pillar trims (both sides), rear wiper motor, rear washer jet, boot lock clip, floor carpet, washer bottle and both pumps, horn, centre/wing brake light, airbox and snorkel. Please let us know if available and price.
thanks, Ben.
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
