lol mw.
Something to say Eddie?
OT: MW Performance is great. Quality work, well priced, is legit, registered with MTQ, isn't dodgy and shadily run with stolen parts. He doesn't sleep in his shed. Doesn't promise to do work then bail on people when the jobs half done/too hard (not saying other real workshops would do this, just an example)
Always had work done there, Car has never missed a beat. made 330hp all day every day for 2 years, built motor, turbo stuff done, 5 stud stuff, cage, everything.
Marty is meticulous with the work he does.
  • 3 months later...
  • 2 months later...
  • 3 weeks later...
Mate there are other people on the coast who know cars. you just have to know them. i knew marty also, he was good at what he does. but saying that, garage redzone is as good also, and am auto are too if you really want to go all the way to noosa. if you can do stuff yourself thats fine. but the reason people are looking for a mechanic is that fact they dont have the skills or the tools to do it, also a time thing where a mechanic can do it in a day or so might take some people 3 weeks, and some cant afford to have there cars off the road for that long.
So all you have to do is talk to these people and check out there work. im sure you will find them more then helpful in these areas.
  • 5 months later...
places not to touch are kawana auto service and Totally Imports. I used to work at Toatall Imports, and the owner is very dodgey in what he gets us to do. Craig at Toruqe and Tune is very good , and so is browns performance in nambour with small things. Don't take anything to top cog. if anything take it down to brisbane to mark at godzilla motorsport or top rpm highly rated workshops with proven background, and stay away from mercury motorsport.
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
