Nic_A31 Posted January 1, 2011 Share Posted January 1, 2011 (edited) Did you have to cut out that area in the tank where the cradle sits inside of? or atleast remove the plastic filter on the outside of that area so fuel flows in quicker? I've noticed both the Bosch 040 and Walbro sometimes struggle in high revs, I'm sure it's just more dirty in my tank, but while using my fuel pump to empty my tank for cleaning, I noticed both pumps can empty that area a tad quicker than it seems to refill when the plastic basket is on the outside ? Edited January 1, 2011 by Nic_A31 Link to comment https://www.sau.com.au/forums/topic/348889-question-for-anyone-w-bosch-040-high-volume-fuel-pump/ Share on other sites More sharing options...
Kris.. Posted January 4, 2011 Share Posted January 4, 2011 i had an 040 in mine shortly after i got it, bottom of the pump hit the bottom of fuel tank it was too tall and kept cutting out as it was clogged with all the shit at the bottom of the tank Link to comment https://www.sau.com.au/forums/topic/348889-question-for-anyone-w-bosch-040-high-volume-fuel-pump/#findComment-5610308 Share on other sites More sharing options...
Nic_A31 Posted January 4, 2011 Author Share Posted January 4, 2011 What did you do after that? With the bosch and a heavily modified cradle I can get it about 5 - 10 mm away from the bottom of the tank. Did you raise the height that the pump sits at? I really don't want to have to clean my tank again but the sock keeps getting clogged. Hoping that if I use this Walbro pump and raise it up higher that I won't have the issue anymore. Link to comment https://www.sau.com.au/forums/topic/348889-question-for-anyone-w-bosch-040-high-volume-fuel-pump/#findComment-5610788 Share on other sites More sharing options...
Kris.. Posted January 4, 2011 Share Posted January 4, 2011 exactly what i did, sold off the 040 and got a walbro, never had a problem Link to comment https://www.sau.com.au/forums/topic/348889-question-for-anyone-w-bosch-040-high-volume-fuel-pump/#findComment-5611309 Share on other sites More sharing options...
dewa32 Posted February 16, 2011 Share Posted February 16, 2011 no experience with 040's but yeah installed a walbro and never had any problems Link to comment https://www.sau.com.au/forums/topic/348889-question-for-anyone-w-bosch-040-high-volume-fuel-pump/#findComment-5674327 Share on other sites More sharing options...
DanShirts Posted March 1, 2011 Share Posted March 1, 2011 I had a 040 in mine. It ran fine, but it was loud. I got mine down to about 10mm off the bottom of the tank. I switched to a walbro because the noise was driving me crazy. I dont know if it made any change, but I pulled the plastic baffle out of mine when I switched to the walbro. Link to comment https://www.sau.com.au/forums/topic/348889-question-for-anyone-w-bosch-040-high-volume-fuel-pump/#findComment-5694688 Share on other sites More sharing options...
daisu Posted March 3, 2011 Share Posted March 3, 2011 I put a walbro in mine about 5 years ago, never had a problem with it... except that I get fuel surge on a particular corner when I get below half a tank. I've since added a surge tank and an external pump in the boot. Link to comment https://www.sau.com.au/forums/topic/348889-question-for-anyone-w-bosch-040-high-volume-fuel-pump/#findComment-5697973 Share on other sites More sharing options...
