hi i have done many searches on this topic and seems im the only one i a nissan that has ever lost reverse!! the gear box just will not find reverse it is just like it not there ive been told it could could be the reverse gear fork but the shifter doesnt move across properly cos it feels weird to get into 5th aswel anyone with ideas?? does anyone have or nowhere i could get an exploded view or manual for an r32/r33 gtr gearbox?? and help would be greatly appreciated!!!
https://www.sau.com.au/forums/topic/348896-lost-reverse/
You're not the only person. Same thing happened to my friend in her 300zx (auto).
She needed a new gear box... life problems solved.
I mean, judging by the sounds of things, it could be a bracket or something that holds the shifter in place, because it's the entire right-hand side of your gearbox. Buutt... get someone skilled to have a quick squizz because it sounds like it needs a new gearbox to me.
https://www.sau.com.au/forums/topic/348896-lost-reverse/#findComment-5607655
  • 1 month later...
Sounds like reverse lock out spring fail.
You've probably noticed when shifting from 5 to 4, it's impossible to hit reverse on the way through. (unless you inadvertantly wobble about while in neutral)
That's the reverse lock out spring.
I've never had to do one so can't help re-the labour involved, but selector balls/springs/detents etc are accessable without removing the box.
Perhaps find out if this guy got sorted.
http://www.skylinesaustralia.com/forums/topic/329424-trouble-selecting-reverse/page__p__5396690__hl__reverse__fromsearch__1#entry5396690
https://www.sau.com.au/forums/topic/348896-lost-reverse/#findComment-5660332
  • 4 months later...
yep spring is proberly the problem.
did mine 5yrs ago.r32gtr.
spring broke, still laying in bottom of box touch wood.
cheap to fix.
passengers side of gbox, 10mm bolt holds lock gate/assembly in place.
smallish assembly teardrop shape.
10mm bolt is the hard bit, very little room need very long spanner, I welded a small ext to make it reach.
and placed a magnet over ring spanner end to help stop bolt falling out of spanner.
A ratchet spanner might be a big help.
https://www.sau.com.au/forums/topic/348896-lost-reverse/#findComment-5864385
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
