VLRB20DET Posted February 23, 2004 Share Posted February 23, 2004 ok ive just put in a new rb20det into my vl commodore, but i have a problem it will crank over but wont start, i have spark and fuel and the ecu says everything is ok anyone got any ideas? Link to comment https://www.sau.com.au/forums/topic/34892-start-you-bstard/ Share on other sites More sharing options...
NuGGeT Posted February 24, 2004 Share Posted February 24, 2004 goto kmart or supercheap ect and buy some "Start Ya Barsted" that should fix it up good n propper Link to comment https://www.sau.com.au/forums/topic/34892-start-you-bstard/#findComment-698297 Share on other sites More sharing options...
blind_elk Posted February 24, 2004 Share Posted February 24, 2004 You've got compression? You haven't been playing with camshafts, and moved them? You can hear the injectors working? You've got the fuel lines on the right way round?? ALL the induction hoses are on? Link to comment https://www.sau.com.au/forums/topic/34892-start-you-bstard/#findComment-698319 Share on other sites More sharing options...
VLRB20DET Posted February 24, 2004 Author Share Posted February 24, 2004 i changed the timing belt over and it went back on fine, everything is ok. im gettin a mate to do a compression test tommorow to narrow dow the possibilites, but i noticed on the ecu the light was flashing and when i went to crank it over the light goes out, im thinking the ecu is not getting power when im cranking the engine. Yeah Nugget i pissed myself laughn when i first saw a mate with that can of that crap.. Link to comment https://www.sau.com.au/forums/topic/34892-start-you-bstard/#findComment-698340 Share on other sites More sharing options...
neil_se Posted February 24, 2004 Share Posted February 24, 2004 I am having exactly the same problem at the moment. My rb20det 180sx is cranking fine but won't fire. I'm thinking it could possibly be the ignitor pack or an ecu connection. Link to comment https://www.sau.com.au/forums/topic/34892-start-you-bstard/#findComment-698351 Share on other sites More sharing options...
paulr33 Posted February 24, 2004 Share Posted February 24, 2004 fuse? Link to comment https://www.sau.com.au/forums/topic/34892-start-you-bstard/#findComment-698807 Share on other sites More sharing options...
VLRB20DET Posted February 24, 2004 Author Share Posted February 24, 2004 gettin compression test done tommorow, soon find out whats goin on! Link to comment https://www.sau.com.au/forums/topic/34892-start-you-bstard/#findComment-698896 Share on other sites More sharing options...
HoeTrain Posted March 11, 2004 Share Posted March 11, 2004 gettin compression test done tommorow, soon find out whats goin on! Don't keep my in suspence any longer please!! Link to comment https://www.sau.com.au/forums/topic/34892-start-you-bstard/#findComment-719933 Share on other sites More sharing options...
VLRB20DET Posted March 17, 2004 Author Share Posted March 17, 2004 ok sorry for a long wait, yeah the compression is ok, ive got spark to the plugs, injectors working, ecu working, fuel lines are ok and the bastard still wont start, the auto electrician it is at has no idea why it wont start, i think i will just take it to JPC in melb and get the pro's to fix it Link to comment https://www.sau.com.au/forums/topic/34892-start-you-bstard/#findComment-729110 Share on other sites More sharing options...
MegaGTS4 Posted March 18, 2004 Share Posted March 18, 2004 As Blind_elk stated have you got the fuel lines on the right way? CAS might be miss aligned or stuffed. It's sounds like fuel or timing to me. Link to comment https://www.sau.com.au/forums/topic/34892-start-you-bstard/#findComment-730858 Share on other sites More sharing options...
blind_elk Posted March 19, 2004 Share Posted March 19, 2004 Is the fuel pump working while the engine is cranking - disconnect the fuel "in" line from the fuel rail and crank the engine (make sure you've got something to catch the fuel in). Alternatively, set the ignition to "on" and then apply battery voltage to the starter solenoid terminal - that should simply crank the engine, and if everything else is OK, the engine should fire. Link to comment https://www.sau.com.au/forums/topic/34892-start-you-bstard/#findComment-731471 Share on other sites More sharing options...
