hey im just wondering if someone can give me some help i own a r33 4 door manual turbo love the car apart from this problem, when i drive the car normal its fine but if i decide to put the foot down flat out as soon as i get to about 4 thousand rpm the car develops a miss firing issue of some sort i have gapped my plugs to .8 and stil have the issue.
the only other problem is it only does it when the air is cooler on a hot day the car seams to be fine any help would be muchly appreiciated
thanks
tyler p
https://www.sau.com.au/forums/topic/348926-r33-4-door-manual-turbo-problems/
It could be coilpacks, bad earth, ecu(Rich & Retard) and/or a myriad of other things.
Sorry i cant offer any more help than that at the moment.
Edited by Shazza24
ok cheers someone else suggested coil packs as well so may have to give that a go. just seams werid that its doing it every know and then but cheers
Its not weird - they do fail in that way. If money's tight, you can use silicon or tape to try and repair them
http://www.skylinesaustralia.com/forums/topic/119403-how-to-fix-missfire-problem/
    • Hi All Does anyone know what size bolts are used to mount the bonnet hinge to the bonnet on an R32 GTR please? I'd usually just buy them OEM but they are nearly £20 each and I need all 4
    • interestingly enough, i found out the answer is yes. doing a flush did fix my recurring A/T light. it might have been because of the trans filter: but that doesn't really make sense to me. the fluid/filter was super dirty. would that increase the pressure in the lines and trigger an A/T light? does the car even have a way of detecting that? i have no idea. i've done 200+ miles after the flush and no A/T light. if my A/B solenoids went bad, i would think the light would've come on. shifts and drives way better now though...at 2k rpm instead of 2500...no hesitation and downshifts when i want it to.
    • I vote go red. Only because I hate keeping gloss black clean. Was no worries helping out either! Glad you've survived the rain outs of QLD
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
