Hey Guys, have my sister in laws 95 RB25Det, developed a noisy lifter, and by the time she got home, the whole top end was rattling.
Car is auto, completely stock, and never sees the blow off opening at all...
I had a listen and determined that there is minimal oil pressure if any, to the top of the motor.
Oil pressure gauge is fine.
Ran a flush through it, changed the oil and filter, still the same.
Fairly sure there is some sort of blockage.
Question, can the blockage be cleared without stripping the engine, maybe removing the cams and blowing back through the oil passages?
Or is there another problem that is causing this, and I am way off base?
thoughts?
Cheers
https://www.sau.com.au/forums/topic/348952-help-series-15-top-end-rattle/
Since you're not getting anything here try posting in Forced Induction Performance :thumbsup:
Cheers, I did get a PM from Jiffo, kinda along the same lines as the course I'm gonna take anyway..
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
