thedesigner Posted January 2, 2011 Share Posted January 2, 2011 hey guys im looking at installing a boost controller (turbotech) in my R33 GTST S1 soon as i am bored with the speed and the cars ready to go quicker. its my daily drive though so im only looking for around 10 PSI. heres the following mods already on the car: FMIC, apexi pod, Splitfire coil packs, dump pipe, 3" exhaust (with a cat) GFB BOV, standard turbo, apexi boost gauge, hks turbo timer. my question is this... will i be able to boost the turbo to 10 PSI or maybe just over whilst still using the standard ECU? or will this extra boost pressure send the sensors crazy? id like to get away with just using the standard ECU if possible as dont want to spend big money. if not what are my options?? mate reckons ill be able to run it on standard ECU no problems... any feedback appreciated cheers. Link to comment https://www.sau.com.au/forums/topic/348989-1st-time-booster-question/ Share on other sites More sharing options...
89CAL Posted January 2, 2011 Share Posted January 2, 2011 33's are funny Mine wouldnt take 10psi, would die at about 5000rpm or so (fuel cut) and was running rich as at 8psi (about 10:1) at this boost with similar mods to you i only made 140rwkw but in saying that ive seen R33's that handle more boost without to much of an issue worth a try i guess but I'd def look into getting an aftermarket ECU. There by far one of the best mods you can do. Power deliever is much smoother and nicer. I have a Power FC and there a great ECU for there age, VIPEC seems to be the way to go now but you could go piggyback in the form of a nistune or greddy emanage or something along those lines if money is an issue Link to comment https://www.sau.com.au/forums/topic/348989-1st-time-booster-question/#findComment-5608487 Share on other sites More sharing options...
17psi r33 Posted January 2, 2011 Share Posted January 2, 2011 hay bloke 10psi is not a problem and also check ebay for the chips that replace your old ecu chip there like 50 buck no rev limiter or fuel cut it will suit what you want to do. no need for power fc yet. chips come pre tuned, as a matter of fact search this web site there would be heaps of others using these chips and the thred can steer you in the right direction for which one to go with. Link to comment https://www.sau.com.au/forums/topic/348989-1st-time-booster-question/#findComment-5608497 Share on other sites More sharing options...
paulr33 Posted January 2, 2011 Share Posted January 2, 2011 please please please DO NOT buy a pre-tuned chip. chips that are tuned for other cars, or remaps are no good and not a good idea. they can be unsafe and be tuned for unknown specs. my recommendation is when you add more boost, is to tune the car at the same time. get nistune and increase the boost to 12psi and your car will be like brand new. there is a lot of power and response locked away in the stock ecu. so if you fit nistune and boost up your car will be like brand new. a powerfc is ideal, but are a bit more costly than nistune. Link to comment https://www.sau.com.au/forums/topic/348989-1st-time-booster-question/#findComment-5608510 Share on other sites More sharing options...
ezy_09s Posted January 2, 2011 Share Posted January 2, 2011 I would be following paulr33 advice and be getting the nistune and adding more boost.. Link to comment https://www.sau.com.au/forums/topic/348989-1st-time-booster-question/#findComment-5608517 Share on other sites More sharing options...
Kinks Posted January 2, 2011 Share Posted January 2, 2011 paul what are your opinions on a custom tuned chip? ie dyno + road tune to figure out what the maps need to be for your particular car and then burn that data to ROM. (main downside i can see is that subsequent retunes are expensive). Link to comment https://www.sau.com.au/forums/topic/348989-1st-time-booster-question/#findComment-5608521 Share on other sites More sharing options...
paulr33 Posted January 2, 2011 Share Posted January 2, 2011 it depends on how they do it, old style remaps used to be like that, burn once and you have to pay full price to reburn it. i think these days its a lot cheaper and things like nistune dont require you to "burn" the tune if that makes sense. the bummer when selling a remap is they are usually worth $0 to anyone else. if you sell a vipec or a powerfc or a motec etc you usually get your money back, nistune you would as well. just do your checking with a remap, im always a bit wary of them. you can get the same power/features etc from them, so don't use that as a deciding factor Link to comment https://www.sau.com.au/forums/topic/348989-1st-time-booster-question/#findComment-5608526 Share on other sites More sharing options...
thedesigner Posted January 2, 2011 Author Share Posted January 2, 2011 thanks for the feedback guys. so how much would a nistune ECU cost and where do i get one from? and how much am i looking at to get everything tuned on a dyno? cant i just get a cheaper piggyback like an Apexi safc to sort out any potential problems when running 10 PSI and dyno tune it then?? hm well maybe ill boost it with the standard ECU for now and see if it starts playing up....if it does ill have to fork out for one of these 2 maybe. Link to comment https://www.sau.com.au/forums/topic/348989-1st-time-booster-question/#findComment-5608635 Share on other sites More sharing options...
Toshi Posted January 2, 2011 Share Posted January 2, 2011 Im remapping R33 ecu also power fc and nistune R32,Z32 ecu tuning. remap is Chip and install socket Cost $100 real time tune labor $450 total$550 Second hand Power fc cost $1200 tune labor$450 total $1650 Nistune cost around $1000 include ecu and labor. So remmap is cheapest option but all ecu almost same performance. Yes,remap is need $100 chip for re tune.(chip can not rewrite) But how many times tune a year. If you will tune once a year , only $100 a year. Nistune is good option. I saw second hand nistune ecu sold $300. So I think you can sale $300 but not $500. my customer car mods is second hand hiflow turbo ($750), second hand Z32 AFM ($150) and my remap ecu ($650 real time tune). Total only $1550. He got 230kw. This is cheaper than second hand power fc and tune. Link to comment https://www.sau.com.au/forums/topic/348989-1st-time-booster-question/#findComment-5608670 Share on other sites More sharing options...
17psi r33 Posted January 2, 2011 Share Posted January 2, 2011 ok so few people to my comments the wrong way i was refuring to a chip you can get tune, was late so i think i said a pre tuned chip. sorry for the retardedness!!! Link to comment https://www.sau.com.au/forums/topic/348989-1st-time-booster-question/#findComment-5608771 Share on other sites More sharing options...
ssxRicho Posted January 2, 2011 Share Posted January 2, 2011 before you grab a boost 't ($80) and nistune ($800) or pfc ($1800), which is the next step (160-220rwkw). do this little mod http://www.skylinesaustralia.com/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/ as the guys have said, you maybe able to run 10psi with the standard tune. but its hit and miss and will run rich and blow crazy black smoke (kinda like a large truck, you may like this...back of the car gets very dirty though...). give this thread a read as well http://www.skylinesaustralia.com/forums/topic/66556-forced-induction-quick-ref-guide/ Link to comment https://www.sau.com.au/forums/topic/348989-1st-time-booster-question/#findComment-5608839 Share on other sites More sharing options...
mosquitocoils Posted January 3, 2011 Share Posted January 3, 2011 Install the controller, wind it up to 10psi, set and forget. You won't have a problem doing that. Link to comment https://www.sau.com.au/forums/topic/348989-1st-time-booster-question/#findComment-5608873 Share on other sites More sharing options...
Rolls Posted January 3, 2011 Share Posted January 3, 2011 put it on 10psi and see what happens, it is highly likely it'll get fuel cut, run too rich and misfire and not make much more power, it might be ok though. Ultimately you want a z32 computer with a nistune or an r32 computer with nistune and get an ebc like eboost street to control the VCT as the r32 computer can't do that, all of these will be ~$1k including a tune installed give or take a bit. Other option is power fc etc which will not pass an inspection if you get defected, up to you. Personally I'd do it once and do it properly and get the nistune, no inspector will be the wiser as it'll have a nissan badge on it. Link to comment https://www.sau.com.au/forums/topic/348989-1st-time-booster-question/#findComment-5608925 Share on other sites More sharing options...
thedesigner Posted January 3, 2011 Author Share Posted January 3, 2011 nistune website says i can pick up a type 2 board for $420. and get one of their regional distributors in WA to dyno tune it. but what does all this other crap on the website mean..... *1 ECR33 RB25DET Skyline can use HCR32DET ECU (no VCT) or Z32 VG30DETT ECU (internal modifications required) *2 BNCR33 Skyline requires BNR32 RB26DETT ECU and O2 sensors??? or check it out http://www.nistune.com/equipment-products-type2.php Link to comment https://www.sau.com.au/forums/topic/348989-1st-time-booster-question/#findComment-5609283 Share on other sites More sharing options...
Rolls Posted January 3, 2011 Share Posted January 3, 2011 (edited) The R33 computer cannot have a nistune module put in it, hence you need a Z32 computer (300zx) and then have it wired in and fitted, or you need an R32 rb20det ecu, however the r32 computer cannot control your VCT (variable cam timing) which you really do not want to go without, however you can use an eboost street to control the VCT as you said you needed an EBC anyway. Email nistune and ask who they recommend in your area to fit and tune a nistune module into an ecu, they will then be able to tell you if they prefer the Z32 ecu or the r32 computer, personally I would just get which ever one is cheaper and get the eboost street either way. Should be able to get an ECU for $100-200, then get the nistune fitted for $300 and wired in I would say would be around $200 depending on what sensors need to be replaced to get it running as they don't just simply plug into the loom. Usually need a series 1 throttle position sensor, if you have a series 2 R33 then you might need ignitor modules etc as well. Either way find out who can do the work for you and call them to ask what they recommend, they might have a second hand power fc that is cheaper than going down the nistune route, however it will never pass an inspection and does not look stock, advantage is it is plug and play. Edited January 3, 2011 by Rolls Link to comment https://www.sau.com.au/forums/topic/348989-1st-time-booster-question/#findComment-5609412 Share on other sites More sharing options...
JonnoHR31 Posted January 3, 2011 Share Posted January 3, 2011 they mean you can use either a r32 rb20 ecu or a z32 vg30 ecu with a few mods (which afaik they now do before selling). the 32 ecu doesnt control vct, so you need an external controller. z32 does control vct so no extras needed. z32 nistune is the best option for a mild r33 rb25 imo but first, buy the turbotech mbc and wind it up to 10psi, some cars will run shit, some will be fine. so try it and see, you wont hurt anything at 10psi. just be sure to keep it under 12/13psi at higher revs, you can get away with a little more in the midrange. Link to comment https://www.sau.com.au/forums/topic/348989-1st-time-booster-question/#findComment-5609418 Share on other sites More sharing options...
