hey guys im looking at installing a boost controller (turbotech) in my R33 GTST S1 soon as i am bored with the speed and the cars ready to go quicker. its my daily drive though so im only looking for around 10 PSI.
heres the following mods already on the car: FMIC, apexi pod, Splitfire coil packs, dump pipe, 3" exhaust (with a cat) GFB BOV, standard turbo, apexi boost gauge, hks turbo timer.
my question is this... will i be able to boost the turbo to 10 PSI or maybe just over whilst still using the standard ECU? or will this extra boost pressure send the sensors crazy?
id like to get away with just using the standard ECU if possible as dont want to spend big money. if not what are my options?? mate reckons ill be able to run it on standard ECU no problems...
any feedback appreciated cheers.
https://www.sau.com.au/forums/topic/348989-1st-time-booster-question/
33's are funny
Mine wouldnt take 10psi, would die at about 5000rpm or so (fuel cut) and was running rich as at 8psi (about 10:1) at this boost with similar mods to you i only made 140rwkw
but in saying that ive seen R33's that handle more boost without to much of an issue
worth a try i guess but I'd def look into getting an aftermarket ECU. There by far one of the best mods you can do. Power deliever is much smoother and nicer.
I have a Power FC and there a great ECU for there age, VIPEC seems to be the way to go now but you could go piggyback in the form of a nistune or greddy emanage or something along those lines if money is an issue
hay bloke 10psi is not a problem and also check ebay for the chips that replace your old ecu chip there like 50 buck no rev limiter or fuel cut it will suit what you want to do. no need for power fc yet. chips come pre tuned, as a matter of fact search this web site there would be heaps of others using these chips and the thred can steer you in the right direction for which one to go with.:thumbsup:
please please please DO NOT buy a pre-tuned chip. chips that are tuned for other cars, or remaps are no good and not a good idea. they can be unsafe and be tuned for unknown specs. my recommendation is when you add more boost, is to tune the car at the same time. get nistune and increase the boost to 12psi and your car will be like brand new. there is a lot of power and response locked away in the stock ecu. so if you fit nistune and boost up your car will be like brand new. a powerfc is ideal, but are a bit more costly than nistune.
paul what are your opinions on a custom tuned chip? ie dyno + road tune to figure out what the maps need to be for your particular car and then burn that data to ROM.
(main downside i can see is that subsequent retunes are expensive).
it depends on how they do it, old style remaps used to be like that, burn once and you have to pay full price to reburn it. i think these days its a lot cheaper and things like nistune dont require you to "burn" the tune if that makes sense. the bummer when selling a remap is they are usually worth $0 to anyone else. if you sell a vipec or a powerfc or a motec etc you usually get your money back, nistune you would as well. just do your checking with a remap, im always a bit wary of them.
you can get the same power/features etc from them, so don't use that as a deciding factor
thanks for the feedback guys. so how much would a nistune ECU cost and where do i get one from? and how much am i looking at to get everything tuned on a dyno? cant i just get a cheaper piggyback like an Apexi safc to sort out any potential problems when running 10 PSI and dyno tune it then?? hm well maybe ill boost it with the standard ECU for now and see if it starts playing up....if it does ill have to fork out for one of these 2 maybe.
Im remapping R33 ecu also power fc and nistune R32,Z32 ecu tuning.
remap is
Chip and install socket Cost $100 real time tune labor $450 total$550
Second hand Power fc cost $1200 tune labor$450 total $1650
Nistune cost around $1000 include ecu and labor.
So remmap is cheapest option but all ecu almost same performance.
Yes,remap is need $100 chip for re tune.(chip can not rewrite)
But how many times tune a year.
If you will tune once a year , only $100 a year.
Nistune is good option.
I saw second hand nistune ecu sold $300.
So I think you can sale $300 but not $500.
my customer car mods is second hand hiflow turbo ($750),
second hand Z32 AFM ($150) and my remap ecu ($650 real time tune).
Total only $1550.
He got 230kw.
This is cheaper than second hand power fc and tune.
before you grab a boost 't ($80) and nistune ($800) or pfc ($1800), which is the next step (160-220rwkw).
do this little mod http://www.skylinesaustralia.com/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/
as the guys have said, you maybe able to run 10psi with the standard tune. but its hit and miss and will run rich and blow crazy black smoke (kinda like a large truck, you may like this...back of the car gets very dirty though...).
give this thread a read as well http://www.skylinesaustralia.com/forums/topic/66556-forced-induction-quick-ref-guide/
put it on 10psi and see what happens, it is highly likely it'll get fuel cut, run too rich and misfire and not make much more power, it might be ok though.
Ultimately you want a z32 computer with a nistune or an r32 computer with nistune and get an ebc like eboost street to control the VCT as the r32 computer can't do that, all of these will be ~$1k including a tune installed give or take a bit. Other option is power fc etc which will not pass an inspection if you get defected, up to you.
Personally I'd do it once and do it properly and get the nistune, no inspector will be the wiser as it'll have a nissan badge on it.
nistune website says i can pick up a type 2 board for $420. and get one of their regional distributors in WA to dyno tune it. but what does all this other crap on the website mean.....
*1 ECR33 RB25DET Skyline can use HCR32DET ECU (no VCT)
or
Z32 VG30DETT ECU (internal modifications required)
*2 BNCR33 Skyline requires BNR32 RB26DETT ECU and O2 sensors???
or check it out http://www.nistune.com/equipment-products-type2.php
The R33 computer cannot have a nistune module put in it, hence you need a Z32 computer (300zx) and then have it wired in and fitted, or you need an R32 rb20det ecu, however the r32 computer cannot control your VCT (variable cam timing) which you really do not want to go without, however you can use an eboost street to control the VCT as you said you needed an EBC anyway.
Email nistune and ask who they recommend in your area to fit and tune a nistune module into an ecu, they will then be able to tell you if they prefer the Z32 ecu or the r32 computer, personally I would just get which ever one is cheaper and get the eboost street either way.
Should be able to get an ECU for $100-200, then get the nistune fitted for $300 and wired in I would say would be around $200 depending on what sensors need to be replaced to get it running as they don't just simply plug into the loom. Usually need a series 1 throttle position sensor, if you have a series 2 R33 then you might need ignitor modules etc as well.
Either way find out who can do the work for you and call them to ask what they recommend, they might have a second hand power fc that is cheaper than going down the nistune route, however it will never pass an inspection and does not look stock, advantage is it is plug and play.
Edited by Rolls
they mean you can use either a r32 rb20 ecu or a z32 vg30 ecu with a few mods (which afaik they now do before selling). the 32 ecu doesnt control vct, so you need an external controller. z32 does control vct so no extras needed.
z32 nistune is the best option for a mild r33 rb25 imo
but first, buy the turbotech mbc and wind it up to 10psi, some cars will run shit, some will be fine. so try it and see, you wont hurt anything at 10psi. just be sure to keep it under 12/13psi at higher revs, you can get away with a little more in the midrange.
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
