I have bronze te37's 18*9 off set 10 with toyo 18*275*35 on my r34 gtr 2001 non vspec....close to new with no marks and they dont scrub
I want to change them for gold gt-c ( always been my favourite)19*9.5 but I dont know what off set I need and tire size.
Would these rims fit like the seller says and r these tyres any good to me. Thanks for any help
http://www.skylinesaustralia.com/forums/topic/348547-fs-19-volk-gtc/page__p__5604692__hl__volk__fromsearch__1#entry5604692
https://www.sau.com.au/forums/topic/349011-r34-gtr-gtc-19s/
Just make sure that once you've decided on offset, such as +12 for your GT-R, that the GT-C rims cover your calipers.
GT-C rims come with a "Face 1" where the spokes are flatter > they won't quite clear your calipers with a +12 offset (unless you use spacers).
GT-C rims come with a "Face 2" where the spokes are a bit more concave > they clear larger Brembos, APs etc with a +12 offset.
Read > http://www.newerapar...0&ProductID=297
*Edit:- I've just noticed that the advertisement is offering a staggered set with offsets vastly different to what I'd put onto a R34 GT-R.
If you still want those with that offset at the front, they will probably clear your Brembos.
*Edit:- I run +12 Offset on my ADVAN RG rims
https://www.sau.com.au/forums/topic/349011-r34-gtr-gtc-19s/#findComment-5608768
edit
:FRONT
19 X 9.5 +37 (will clear big brakes, have tested) - Face 1 with no tyre.
REAR
19 X 9.5 +46 - Face 2
Brand new Nitto tyres - 225/35/19 (should re-fit these to the front and get bigger once to the rear) would these tyres be any good to me on the front ???
Thanks for any help
here is the link to the rims
http://www.skylinesa..._1#entry5604692
https://www.sau.com.au/forums/topic/349011-r34-gtr-gtc-19s/#findComment-5609119
i dont know much about offset and stuff but they would look super gay on a gtr, i got 17x9.5 37 on the back my gtt and they sit in like 1.5-2cms in the guard
yes i agree that would look gay times 10
yes i dont want to use spacers... so off set +37 face 1 for the front any good .....off set +46 face 2 for the back any good... if not what would be the correct off set to buy if i had to buy new..
https://www.sau.com.au/forums/topic/349011-r34-gtr-gtc-19s/#findComment-5609150
  • 2 months later...
  • 1 month later...
Hey guys/ girls
I have a R34 GTR and i'm very interested in getting GT-C 20 x 10.5 +12 Face 2
Would that muck around with my 4wd system ? Coz I dont wanna settle with 19in
And would i have to do any modifications to make them fit ?
https://www.sau.com.au/forums/topic/349011-r34-gtr-gtc-19s/#findComment-5803044
I have Volk GT-C face 2 19x9.5 on my 34 GTR the offset is +11 the tyres are 275/30 this is what rays engineering recommanded to use on a 33/34 GTR with 19x9.5, not sure how much difference +12 would make as terry has recommanded
For future reference
Some of the info in this thread is not correct (points finger at Terry, nicely)
I run 19x9.5 +12 GTC's Face 2 (BAKES old R34 GTR wheels)
He use to run a 3-5mm spacer to clear the Brembo's
+12 Face 2 are "B" disk. They miss my R34 GTT calipers by 1mm
+11 Face 2 are "A" disk which are for brembo's. Only 1mm different in offset but 5-6mm difference in caliper clearance
You can confirm this reading the Rays wheel charts
The difference in extra calpier clearance on the A disk +11 is done by running a smaller outer rim width (less dish) than the B disk +12.
https://www.sau.com.au/forums/topic/349011-r34-gtr-gtc-19s/#findComment-5816167
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
