I'm going to be installing a pair of 9.7mm 272 camshafts and HKS cam gears in my RB26 soon. Just wanted to know if there is any tips or advice on how I should tackle this? I've read about people doing a cam swap without completely taking the timing belt off. How can this be done?
What parts (gaskets,seals, etc..) should I replace whilst I have everything apart? The head has been rebuilt (still to standard specs) and has HKS Step 2 valve springs already instalkled.
Thanks
Edited by Chris32R
https://www.sau.com.au/forums/topic/349031-installing-cams-in-rb26/
You can do the cam swap without removing the belt, you need to remove the cas bracket, and cabletie the cam belt to the camwheels. support the gears so they dont frop. Make sure you sneak the cams down gently and evenly or the cam canbe snapped. I do the cam swap with the motor about 20degrees before top dead centre. Might as well replace the valve cover seals at the same time if you havent already done so.
Ok to make sure that i got this right. First thing to do is remove Cas bracket. Turn the motor to 20 degrees before TDC (I thought it was easier to have it lined up right on TDC?). Cable tie cam gears to timing belt and support cam gears so that they don't fall. Undo and carefully slide both cam gears evenly off the camshafts. The rest of the process is just slowly and evenly undoing the cam caps starting from the middle and working your way out. Remove cam. Lubricate the new cam lobes, cam buckets, lifters and journals. Install new cam and slowly tighten cam caps starting in the middle working your way outwards.Install new cam seals. Replace the old cam gears with your new ones making sure that they are in the same position as the old ones. Install cam gears. The rest of the process is pretty self explanatory.
Am I on the right track? Anyone know the torque rating that I should torque everything to?
Edited by Chris32R
If its your first time doing a cam change then I would recomend doing it by taking off the belt. If your not familar with doing it without taking the belt off it might turn into more of a hassle then hoped for. But then again guess you wont learn how to do it until you have a go/
I hope the head was clearanced for the high lift cams when it was rebuilt because 9.7mm lift cams will not fit an un-clearanced head. I recommend removing the belt as well. So radiator out, fan off, harmonic balancer off, bottom cover off. Align your timing marks on the oil pump and cam backing covers and then work the service manual.
The service manual contains all the torque specs you will need, and you definatly should not be attempting this if you dont have a copy of it. Its also worth considering changing your idler and tensioner bolts with new ones, and possibly the bearings themselves if they are aged.
Always torque exactly to spec as well.
Remember RB26's are interference engines, and it will end in tears if you dont do it 100% correct!
I beleive the 9.7mm cams I've got are the biggest lift cams made that could fit in an unmodified head. Yep I've just downloaded the service manual and yeah I always torque every bolt that i can up to the required spec. I'm very fussy when it comes to my cars :).
Where can the idler and tensioner bolts be purchased from?
Thanks for the help.
Get the idler bolt and tensioner stud from Nissan. Use genuine parts only.
I think you want to double check that cam clearance too. I know the JUN cams of the same lift use a smaller base circle to get more lift at the lobe, so you can also count on needing a complete set of custom bucket shimms too.
Ok thatnks.
Yeah the cams are Jun 272 9.7mm lift on both intake and exhaust. So now do I need shims when I install them? Hmmm this is starting to sound very complicated. I thought the Jun cams would just drop straight in and nothing else would be needed except new seals, gaskets, etc...?
Edited by Chris32R
Ok thatnks.
Yeah the cams are Jun 272 9.7mm lift on both intake and exhaust. So now do I need shims when I install them? Hmmm this is starting to sound very complicated. I thought the Jun cams would just drop straight in and nothing else would be needed? except new seals, gaskets, etc...
To install them properly you do a trial fit with no shimms installed. You then need to measure the distance between when the cam bucket and the cam at 0 lift so you can work out what thickness of bucket shim to use. You have to rotate the engine over by hand with both the cams installed when doing this, so you can measure from the middle of the back of the lobe to the cam bucket.
Once you know your cam clearances for all 24 valves you can order the appropriate thickness shims. Jun cams use a recommended 0.3mm intake and 0.33mm exhaust clearance. There is a few tricks when installing them too, such as using wet and dry paper to trim the shims up precicely, and also to take the sharp edges off the machined edge of the shim, so that it fits better into the back of the bucket.
The importance of getting this right makes the difference between having an optimal setup, having a less than optimal setup that is noisy like a tractor, or having a valve not seal against the seat which will result in a burnt valve seat and head damage or worse.
Just a question while on the topic, do you use loctite on the tensioner stud when changing it?
What do you guys use to hold the cam gear in place to slacken/ tighten if changing gears alone without taking off the valve covers?
Any tricks?
Chris...youre suppose to slacken the caps from the outside to the inside when removing
Edited by Don Dada
I have the same cams 272 9.7mm. Shims were required. Dan from ERD did all the work of measuring and ordering the right sizes.
Light grade on the end of the stud that goes into the block, and on the idler bolt thread. The wavey locking washer under the nut and the correct torque spec for tightening the nut do the rest.
Nissan know what they are doing when they design these things so there is no need to over think, or try and over engineer something that is already thouraghy tested, designed and approved by teams of engineers. Everything you need to know is in the manual.
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
    • I actually have an aftermarket hanger, the detschwerks x1 hanger, but my dw420 has never really sat in it correctly, good to know I can just modify it a bit to suit. Yeah cheers man will definitely have a play with it and hope it solves my dramas.
