R33 GTS-T Series 2 Skyline - Gunmetal Grey
Please PM me via the forums, send me an email to [email protected] or call me on 0407 229 095 (after 4pm on weekdays) if interested.
Please note: No joy riders! We've heard too many horror stories.
Also no paypal payments.
Excellent performance and handling, owned by female owner since import in Oct 2002. Rego renewed till Oct 2011.
2.5L to 3L conversion engine professionally built by Pro Concept Racing in Seven Hills late 2006/early 2007, producing 324RWKW on very conservative boost and tune. Also regularly serviced with log books by Pro Concept. All receipts still held and available for inspection. 141,000kms clocked with 45,000km done since the rebuild with only general day to day driving, no thrashing.
Too many modifications to mention, snapshot below, please contact for any inquiries.
ENGINE:
Garrett GT3076 Turbo Charger
Nismo Oil Cooler
Greddy air inlet manifold/plenum
HKS BOV
Front mount intercooler
CP Pistons and rings
Tomei head gasket
Tomei Valve Springs
ARP Studs
Nismo engine mounts
Custom piping
Nismo 550cc Fuel injectors.
Splitfire Coilpacks
Apexi Power FC programmable ECU with hand controller
DRIVETRAIN:
Nismo twin carbon fibre plate clutch
Cusco lightened flywheel
Upgraded slotted brake rotors front and rear
Custom Turbo back exhaust from HiTech Mufflers to meet EPA requirements
HANDLING:
Tein adjustable coilover suspension
Front and rear strut braces
WHEELS:
Volk TE37 Bronze – 17” x 8” front, and 17” x 9” rear
INTERIOR:
Defi 3 x gauge cluster – Oil Temp, Water Temp, Oil Pressure
Greddy boost controller
Turbo Timer
SECURITY:
Currently has QuikTrak installed and can be transferred to the new owner
PICS:
ASKING PRICE:
22k ono
https://www.sau.com.au/forums/topic/349083-fs-1997-r33-gts-t-324rwkw/
Oh weird! Didn't even get notified that there was a response on here!!
Thanks dude :) I think its finally time to let go :(
I'm willing to drop on price for reasonable offers.. the car really is a rocket ship... beautiful to drive... its just wasted on me these days... using it as a daily driver doesn't make sense anymore :)
PM or call if interested :)
Mona
  • 4 weeks later...
pity your not in perth. Id do swapsies with my GSXR 750 for that thing...
good luck with the sale mate. Nice dirty 30 sleeper :)
Nawww... that would have been awesome!! And thanks :)
swap for a 270rwkw R33 GTR with some cash my way??
and nah thanks.. really a moving away from the whole scene :P
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
