Gold Coast / Brisbane Cruise
Are any users interested in doing a Gold Coast / Brisbane Cruise??
Meet on the coast, cruise up to Brisbane to say harry's diner or something so we can meet a few of the other members?
Other Brisbanites can meet us there as well?
if i get enough interest ill organize something.
it would be a Thursday night meet 6.30 ish arrive at harry's say 7.45ish.
r6n, there is always a big meet at harry's on thursday nights thats all.
every other night its kinda dead.
we can do it another night if it suits everyone but there wont be any cars at harry's really.
I think first time we will just tag along on the Saturday night cruise with hardtuned.net, then we will definitely organise a weeknight cruise.
just the organisation has been done by loz and keish for the sat night one and well it seems too good to miss.
then we shall organise our own
Im going to try and make this one, who is going? Can someone post a link, i cant find it on hardtuned.. Thanks
Well if it has been postponed, we should tee it up for a cruise before then.
KEEN!
ill listen to the news and see. looks like harrys should have a decent turnout next week depending on weather. maybe have a gc start cruise, and meet with the brissy guys to cruise there together?
KEEN!
Im still keen to meet up, i canceled some stuff on sat just to go and now its pushed back..
i think i may organise something still then if people are keen. same meet spot (clive peters at goldcoast 6pm (6.15-6.30 leave))
we could cruise down to byron or something for a little bit of a different run?
same rules apply as on every cruise don't be a wanker thou.
Edited by Cobey
Highway cruise to Byron or like scenery cruize through advanced town into nsw and back up?
either or? im just worried some of the back roads may be a bit "destroyed"?
I jumped on the R6 and went for a ride with a mate down advanced town, didnt get all the way there but turned around at that bridge and roads were fine that far.. saw about 2 little pot holes and thats it. Depends where everyone wants to go. I don't really mind, i just like the hills as you can go fast without going much over the speed limit at all. Doesnt matter where we go, Im just stocked we finally have one planned! :D
 Share
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
    • It also depends on gearbox ratio. Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm.... ....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc. That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
    • but for how long? would it handle a few laps around SMSP in anger?
    • And over it. Need to stop it coming through the floor.
    • Is it running the standard ECU? some sort of data log might help understand where timing, AFRs etc are at.  If it is standard ECU something like Nissan Datascan would help
