  • Replies 53
Wow..thats actually alot more affordable than i had imagined..
Well worth considering
What would a quick rebuild on a 25 block set you back, im thinking 1500-2000 with rebore, quality bolts, bearings and pistons.
Only thing Im worried about is your turbo not liking the extra capacity cause then your going to be forking out for new turbo as well, then you would probably need new injectors .....................
And so on the snowball begins.
Edited by Arthur T3
Maybe,
Does your turbo drop off now or would it handle a 8-8500rpm redline?
Cause i get the feeling that some more revs and some extra comp (say 9.5) would make it deadly fast and responsive. But im only guessing.
Are you talking about if he stayed RB25?
His turbo would not handle 8,500rpm redline on an RB30. I think joey would be happy if it handled 7000rpm well on the RB30. That was my point that 9.5 comp would be super nice on the RB30 but I think the RIPS standard refreshed engine is a great deal.
Yeah was talking about a built 25..
RIPS is a good deal but is it compatible with his current setup is the big Q. I mean its no good getting it to find out its not, then you have to spend as much again to set it up properly.
But a decent bottom end that can handle 8000rpm , decent pistons alone could provide some extra torque, It may not make much more power but it will make it quicker and stronger for longer..
Plus buying an engine form NZ means alot of hassles if it plays up, not like u can drive in and complain, and there is plenty of good engine builders nearby his area
Im not knocking the 25/30 at all just adding another point of view.
Edited by Arthur T3
yeah i'm just trying to research it all atm... that turbo was still climbing when it was shut off at 7400 but not very steeply
i'm thinking that it's really not that much smaller than the 3076 .82, so it should manage a redline of 7000 or just shy of...
The HKS 2835 Pro S seems to have just as much top end as a 3071 0.82 on an RB25. And there are plenty of results similar to the 3076 0.82.
Even if it does nose over just before 7000rpm that would still be a very nice setup. The other thing I was thinking of is that the HKS 2835 Pro S came in a 0.87 exhaust housing although I am not sure if it is T3 as well. A 0.87 exhaust housing would be ideal imo
yeh... i'm thinking this should be a goer :)
worst case scenario will be a new rear i spose, but if it makes 6500, i'll just set the redline to 6,800 and be done with it ;)
Even if power drops off, as long its more power than the next gear up at that speed you are still better off revving it out to 7,000rpm or whatever the engine is safe to. Same as how a standard turbo power drops off over 5,500-6,000rpm but you are still better revving it out to rev limiter.
Check out this link:
http://www.allpar.com/eek/hp-vs-torque.html
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
