hey all.
just went to put my rb25det oil filter adaptor onto my new rb30det engine and notice it doesnt look right.
the rb30 block has a threaded male outlet but the female hole in the rb25 adapter is not threaded and is slightly larger in diameter.
doesnt look to me like it will seal properly.
see pics below.
Do i need to source an rb30 adapter? im now guessing the the 25 and 30 adapters are different?
https://www.sau.com.au/forums/topic/349149-which-oil-filter-adapter/
yep, they both unscrew. if your having trouble getting the 25 one out i used the tool for changing discs on a makita angle grinder, perfect fit. as for the 30 one, i used nut munchers because i wasnt gonna use it, but if you want to keep it find 2 nuts in the right thread and lock them together.
also make sure you use a new gasket and everything seats properly, i cracked my filter housing from it not sitting right and tightening it up just a little. had to find another one, was a PITA
Edited by JonnoHR31
i kept the factory water cooler setup. havent taken any temp readings but water temps always nice and cool so i cant see it making the oil hotter.
i agree its not ideal but for a basic 30det it does the job
oh so the 30 doesnt have an adapter. the filter screws straight to the block.
eventually i will run a proper oil cooler it is a track car but for run-in and tuning i just need to get it going.
when i buy an oil cooler kit will i be needing the threaded male peice in the block or the unthreaded male piece?
i dont want to be swapping these once engine is in the car so if i need threaded later i will just put oil filter staright on block for now?
But if i need the unthreaded later i will do that now and run 25 oil to water cooler untill i buy oil cooler?
Thanks guys
(or will wether i buy a 25det or 30e oil cooler kit effect what peice in need in the block lol?)
You need to attach the oil filter block to the engine block, so you can screw on the oil filter or adapter for the oil cooling system. I'm pretty sure you cannot connect it straight up to the engine block as that's how I was going to get around replacing my oil filter block.
Also, FYI - you will need a gasket for the oil filter block to against the engine block. Justjap sell and stock them http://www.justjap.com/store/product.php?productid=18637&cat=318&page=1 so you don't have to buy one off nissan directly.
Here's a picture of an oil filter relocation kit just so you can see what I mean (you need the thread to hold the connector on there, it wont attach directly to the engine block): http://www.full-race.com/catalog/images/s2000%20oil%20filter%20relocation%20kit1.jpg
thanks for the input erderr
yer ive got a gasket. it came with one of the gasket kits when my 25/30 was built.
so did rb30 have a different oil filter block or not run one at all?
i dont want to use the 25det oil filter block because it has the huge hole cast into one side of it for the factory water cooler which i do not want to use.
so i still need a 30e oil filter block then is what your getting at? one that wont have provision for the water cooler just the filter?
(and obviously i chuck the sandwhich plate for the oil cooler kit where the filter would usualy sit on the 30e oil filter block?)
*tells girl friend to take me to wreckers to look at a vl commy oil filter block*
lol
thanks james
this must mean that oil cooler kit for 25 and 30 will be different?
one will take a thread (30e kit) and one will slide on and use the bolt holes round the outer (25det) ?
i cant see the oil cooler sandwhich plate in the 25 kit going onto the already existing factory warmer/cooler. surely it stil goes onto the block?
  • 1 month later...
how did you go with this mate?
i'm going the same thing my self atm & want to get rid of the water cooler but not 100% sure what hose/lines to remove/block, can anyone give me some directions on this please. didn't hapen to get some pics before you put the engine in did you, so i can see how you have it set up?
cheers
Hey mate. I ditched the 25 water cooler setup in the the end. I currently have an oil filter straight on the block. As this is an engine built from scratch I will try to do a fare extensive run in so no cooler will be needed until I get it tuned again and track it.
As soon as its run in and I put the filter relocator and cooler on I will take piccs. Being a track car I dont run a heater or anything so there isnt many coolant lines left lol.
oh ok i'm just not exactly sure what lines to remove.
do i just take all the lines from that rear water feed?
    • Gotcha, I mean that is at least good to hear. Are there signs, or troubleshooting tips to make sure the transmission is operating properly?
    • Well thats probably not gonna happen right away. LOL
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
