hey all.
just went to put my rb25det oil filter adaptor onto my new rb30det engine and notice it doesnt look right.
the rb30 block has a threaded male outlet but the female hole in the rb25 adapter is not threaded and is slightly larger in diameter.
doesnt look to me like it will seal properly.
see pics below.
Do i need to source an rb30 adapter? im now guessing the the 25 and 30 adapters are different?
https://www.sau.com.au/forums/topic/349149-which-oil-filter-adapter/
yep, they both unscrew. if your having trouble getting the 25 one out i used the tool for changing discs on a makita angle grinder, perfect fit. as for the 30 one, i used nut munchers because i wasnt gonna use it, but if you want to keep it find 2 nuts in the right thread and lock them together.
also make sure you use a new gasket and everything seats properly, i cracked my filter housing from it not sitting right and tightening it up just a little. had to find another one, was a PITA
Edited by JonnoHR31
i kept the factory water cooler setup. havent taken any temp readings but water temps always nice and cool so i cant see it making the oil hotter.
i agree its not ideal but for a basic 30det it does the job
oh so the 30 doesnt have an adapter. the filter screws straight to the block.
eventually i will run a proper oil cooler it is a track car but for run-in and tuning i just need to get it going.
when i buy an oil cooler kit will i be needing the threaded male peice in the block or the unthreaded male piece?
i dont want to be swapping these once engine is in the car so if i need threaded later i will just put oil filter staright on block for now?
But if i need the unthreaded later i will do that now and run 25 oil to water cooler untill i buy oil cooler?
Thanks guys
(or will wether i buy a 25det or 30e oil cooler kit effect what peice in need in the block lol?)
You need to attach the oil filter block to the engine block, so you can screw on the oil filter or adapter for the oil cooling system. I'm pretty sure you cannot connect it straight up to the engine block as that's how I was going to get around replacing my oil filter block.
Also, FYI - you will need a gasket for the oil filter block to against the engine block. Justjap sell and stock them http://www.justjap.com/store/product.php?productid=18637&cat=318&page=1 so you don't have to buy one off nissan directly.
Here's a picture of an oil filter relocation kit just so you can see what I mean (you need the thread to hold the connector on there, it wont attach directly to the engine block): http://www.full-race.com/catalog/images/s2000%20oil%20filter%20relocation%20kit1.jpg
thanks for the input erderr
yer ive got a gasket. it came with one of the gasket kits when my 25/30 was built.
so did rb30 have a different oil filter block or not run one at all?
i dont want to use the 25det oil filter block because it has the huge hole cast into one side of it for the factory water cooler which i do not want to use.
so i still need a 30e oil filter block then is what your getting at? one that wont have provision for the water cooler just the filter?
(and obviously i chuck the sandwhich plate for the oil cooler kit where the filter would usualy sit on the 30e oil filter block?)
*tells girl friend to take me to wreckers to look at a vl commy oil filter block*
lol
thanks james
this must mean that oil cooler kit for 25 and 30 will be different?
one will take a thread (30e kit) and one will slide on and use the bolt holes round the outer (25det) ?
i cant see the oil cooler sandwhich plate in the 25 kit going onto the already existing factory warmer/cooler. surely it stil goes onto the block?
  • 1 month later...
how did you go with this mate?
i'm going the same thing my self atm & want to get rid of the water cooler but not 100% sure what hose/lines to remove/block, can anyone give me some directions on this please. didn't hapen to get some pics before you put the engine in did you, so i can see how you have it set up?
cheers
Hey mate. I ditched the 25 water cooler setup in the the end. I currently have an oil filter straight on the block. As this is an engine built from scratch I will try to do a fare extensive run in so no cooler will be needed until I get it tuned again and track it.
As soon as its run in and I put the filter relocator and cooler on I will take piccs. Being a track car I dont run a heater or anything so there isnt many coolant lines left lol.
oh ok i'm just not exactly sure what lines to remove.
do i just take all the lines from that rear water feed?
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
