its more the drunken idiots id have to contend with throughout (while standing in line...). and im not sure they let cripples use firearms. lol.
ill see how i go.
Edited by scandyflick
Yep was good as always. Don't remember much after about 4pm, but apparently the wife picked Scandy, Whiplash and I up then Nick walked home from near my place, and Scandy played some pool at my place. Was fair drunk and stumbling around until midnight when I finally went to bed. Drank over 1lt of water during the night and woke up 100% on Sunday :)
There were many fine girls about, the food was good and the German beer was great.
lol that is the exact song I thought of when I read what Krishy wrote - classic quote from Stallone in Judge Dredd .... and awesome music back from the days when I loved all the classics
Apotheosis - O Fortuna
http://www.youtube.com/watch?v=WJ76EOVpQMM
Praga Khan - Injected with a Poison
Nightcrawlers (where my nickname emanates from) - Push the Feeling On
I could go on for hours of classic from the early/mid 1990's rave days :) .... damn I must be old :D
    • Hi Everyone, I did 4.11 gears in my 34 GTR and only thing that remains is to fix the speedo reading (it reads about 15% higher) using the R33 GTR speedo sensor. Few questions:   1. Does the R33 speedo sensor fit right in to the 6sp getrag? I read it does but wanted to confirm because the speedo sensors between 33 and 34 look quite different   2. The connector on the 33 speedo sensor will not plug into the connector on the getrag. Do I just need to wire the pins together manually?  See pic: https://imgur.com/a/NTDzFe8
    • Does anyone know how I could find the part number for bolts used with  r34 with rb25detneo engine lower timing belt cover?   my timing cover was rubbed and i fixed it but upon putting the harmonic balancer i see the timing cover is almost rubbing and that is due to previous owners using general bolts and washer rather than the bolts per link below which sits inside the washer and pull the cover in   not sure if those bolts will fit rb25   https://www.ebay.co.uk/itm/326510870741?gad_source=1&gbraid=0AAAAAB_7XZxjuciMybdVOTShCs9857686&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338723872&toolid=20006&customid=7jIl12glAAAAVfHSSnyxAmSsdRxnAAAAAA
    • If the slightly higher internal EGR caused by a high flow cat causes detonation your tuner was way, way, way too aggressive to begin with. Timing scatter is a problem unless you go to a crank trigger, winter vs summer blend has different octane, list goes on.
    • The H1 Alpha with the 6.6 Duramax is basically the actual powerplant it needs to be remotely ok to drive on public roads. It's just not worth the cost to buy a real one. Humvees look cool but man the reality of them is depressing. Grunts aren't kind to them but they aren't that reliable either, they have horrible payload despite absolutely massive size, zero actual armor against mines/small arms, absolutely anemic naturally aspirated diesels, list goes on.
