hey guys
My cars coming back from the panel beater early next week and im trying to sort out this speedo problem.
Basically its showing double the speed but this only happened when i installed the turbo intrument cluster..
Does anyone know if theres a difference between the non-turbo and turbo speedo sender on the gearbox's..
or do you reckon its the speedo thats stuffed?
because i dont want to spend a couple of hundread to get the speedo corrected only to find i could have fixed it for $30..
Also would it be hard to wire up the PSI reading to the cluster?
cheers
https://www.sau.com.au/forums/topic/349198-speedo-advice/
don't bother wiring up the stock boost gauge in the cluster get an aftermarket one it will be more accurate
i know there are calibrating points on the back of speedo's its probably one of those needs to be soldered up or un-soldered
https://www.sau.com.au/forums/topic/349198-speedo-advice/#findComment-5610968
Gauge Works - 1004 Port Road
Albert Park SA 5014
should be able to help for a decent quoted price.
my fireblade did this (dble speedo) after gearing sprocket change, cheap fix to get it accurate to over 300kmph
https://www.sau.com.au/forums/topic/349198-speedo-advice/#findComment-5611550
I changed my NA gearbox to a turbo gearbox and had no differences in the speedo readings. So if the gearbox puts out the same ratrio then I think the dash should be the same if its turbo or not.
https://www.sau.com.au/forums/topic/349198-speedo-advice/#findComment-5611623
