okie i ordered my new TRUST catch can today and was asked if i want the 6mm or 10mm version, which is that ? i have a 33gtst with front mount exhaust, highflow panel filter, powerfc, ebc boosted to 0.85bar
which would i go for or doesnt it matter ? im not sure what the size is actually of ? im assuming the hoses ?
https://www.sau.com.au/forums/topic/34921-urgent-catch-can-q/
bahahaha, he didnt slap me he already knows, he spent a day trying to source me a turbo with internal gate :D
he prolly jst said he was looking n sat there n had a beer n giggled at my lameness :D
well i dunno, i just dun got the munny for new manifold n gate :)
guess i could just save n get it later
baa.. here you go again ! can't help yourself can you? With the right low-mount turbo, l3thal will be spinning away while you're forced to take it easy ..making sure you don't snap into the red zone at the wrong moment.
Not everybody needs to go for a massive high mount, external wastegate, etc, etc - we're talking *street* cars anyway. Not that you'd ever get out on the track or the drag strip anyway Insant!
if u r gonna spend so much money on a turbo then y not have it so everyone can see it!
Y would i be forced to take it easy, and snap into what redzone??? i can take off the at 4000rpm with a bit of wheel spin in first/second while nathan would be adjusting him blue undercar neons, heheh :D
I will be hitting the strip with some nittos soon, and i will video tape it and send it all the way to you in qld to watch, u vic traitor :D
Have you driven it in the wet yet? And being Victoria, you're gonna get plenty of it during winter!
You'd better!! and you better get 12's.. but when the defect notice and EPA comes knocking at your door, I know what state I'd rather be in ..
I now have a second car, my gfriends new mazda which i can drive around in for shopping etc as she now lives 2 mins away from me.
As for defects and epa, been there, done that in both of my previous cars :wassup:
    • I've sent JaseR33 a private message in the hope he gets an email and contacts you
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
