Hi I am new to the site, and am currently working on a S13 240sx with an RB25 R34 NEO engine swap. Due to my turbo placement and intercooler piping setup i bought a Greddy "style" intake manifold. My question is what have others done to use the NEO's top feed style injectors with the Greddy style manifold. I made a bracket to physically relocate the fuel rail but there is considerable slop between the injector and the injector bung walls on the manifold. Looking for some ideas as to what others have done to make this combination work
OR....
Are there any cheap alternatives in terms of fuel rails or easy to source stock injectors from other models that may fit (keeping budget friendly in mind haha) I am in the states so r33 injectors and fuel rails dont pop up too often for sale.
Thank you! I have spent a lot of time searching for the answer but not a specific solution other than many people buying new rails and aftermarket injectors. Thanks!!
Edited by getslideways
I just got NEO fuel rail mounts rewelded to a position suitable for Greddy manifold. Costed ~20$.
Do you have any pics? If so it would be greatly appreciated! Also what did you end up using for injector o-rings/sealing rings? Thanks!
I made a bracket to relocate and space the NEO fuel rail and injectors that seems like it will work (still curious to see yours) but now need to make a good seal between the NEO injectors and the inside the intake manifold injector bung somehow, since there seems to be some slop and not air tight
thanks!
or gtr rail and spacers. Use the rb25 rubber seals in manifold or get adapters.
http://www.skylinesaustralia.com/forums/topic/306527-r33-greddy-inlet-plenum-onto-a-rb25det-neo/page__hl__greddy+inlet+neo__st__20
I have done this conversion on my neo
Read my last post, item no.6
Edited by darrinspencer
Hey Darrin,
so theres no aftermarket fuel rails out there to accept the GTT/Stagea injectors?
i wanna do this but dont want to change my injectors.
When I set my imitation greddy manifold on my neo motor, I fitted factory gtt injectors and rail, by slotting the holes in the rail, and making a spacer. and got new O-rings that had thicker sidewalls. Fitted tight. cost 5 dollars from a local bearing supplier. Just make sure if you do do this they're up to withstanding fuel.
Hey Darrin,
The aftermarket fuel rail (cheap chinese HKS copy) fits the injectors.
What the OP was asking was how to fit the neo injectors in the greddy manifold as the greddy is made for R33 side feed injectors.
All you do is keep the standard O ring on the bottom of the injector plus add the R33/S15 larger grommets to fill the manifold.
As long as you have enough clampping pressure on the rail they will seal
Status posted some pic's on here somewhere showing a close up.
Cheers for that,
so these would fit my neo motor? Some say " Single entry single return configuration", my rail has 2 regs, can i still use both regs
http://cgi.ebay.com/ebaymotors/R32-R33-R34-GTS-BILLET-INJECTOR-FUEL-RAIL-RB25DET-RB25-_W0QQcmdZViewItemQQhashZitem3363e700ebQQitemZ220719415531QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Cheers for that,
That is exactly what I used, but I did away with twin factory reg's and fitted a Sard one, even thuo I did not really need and adjustable one with the siemen 650cc injectors I used.
Just be away of the cheap copies. I had fuel leaking from both ends and had to get the end re machined square to seal.
I may just have got a dud one which is not unusual for cheap chinese crap.
Can buy genuine HKS but $300++
thanks!
Sorry for delay, didn't see your message.
I used slightly fatter than factory lower o-rings + some kind of hard rubber for bigger manifold o-rings, I don't know how to properly call this part. Installation is somewhat messy, but there is no vacuum/boost leak, so it all works for me. I'm currently using factory injectors, so I didn't use any spacer for a rail.
As for pics, I'll try to arrange that in a week.
Edited by Legionnaire
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
