  • Replies 48
Posted Images
ive got a set of 555cc bosch yellow sidefeeds, almost brand new (only 4000km's on them) perfect condition for $650
admitadly for $1000 (what they cost me new) that would make them less apealing then getting the std ones highflowed...
I originally had highflowed injectors... had them tested and the spray patterns were terrible!
wasnt going to put the engine at risk just for the sake of cheap injectors!
^^ +1 on that.
when your simply burning a hole through the injectors, the spray would only be good at a higher pressure right(when you duty cycle is higher) correct me if I'm wrong, but wouldnt this give you a sluggish acceleration, or very "rough Idle" as the fuel would literally be 'trickleing' out?
I bought some 610cc Seimens Deka(chasing 300awkw e85) - Dark blue/black. they look stock. they are a four port which means its a good spray even at low rev's, i'll get a nice constant idle, a good acceleration, and a good mid-top end aswell. Now I just gotta get the buggers in.
Just remember people that stock injectors are very old, new ones use new tech and can have much better spray and atomomisation, so not only do you risk making and old design worse, you are missing out on new tech. You don't even save that much money.
yeah maybe your right maybe aftermarket ones migh be the way to go te only thing confusing me is alot of people say they have them and have never had a problem and alot say they are crap. o well when it comes closer to changing the injectors in the next few months ill look at my options alot more closley
Yeah but most people don't know what they are talking about, misfires, poor idle they are all used to. If it makes power then it must work!! Doesn't mean it works well or that it is better than stock!
