Hi guys,
Item For Sale:
KKR560 Turbo and Dump Pipe, V-band Clamp, and Oil Lines
Reason For Sale:
Upgrading to external gate GT3076 that a friend sold to me for the right price
Availability:
Turbo will be removed around 17th of January, so if you want to come test drive it while it's still on my car, just give me a call :)
Installation Instructions:
I installed it two years ago, but pretty sure you will just need a few silicon joiners and stuff to replace the stock turbo, and use stock oil return line. This turbo is not water cooled, so you can block those off. I followed a tutorial i found on this site to get it installed, and has gone 2 years without troubles
Price:
$500 pickup, or buyer pays postage.. or make me an offer, as this is no longer needed
Gold Coast, QLD
Hi guys,
I bought this turbo when it was only a few months old off the SAU forum about 2 years ago. It had been purchased from AutoBarn two months prior. From the start, it had boost control issues, like most KKR turbos. I took it to MR turbo, who removed the "twin scroll partition" from the exhaust housing, as the wastegate was only able to vent gases from 3 cyl instead of all 6.
It still had boost control issues after reinstalling, so i took it off again, and they made the wastegate hole much larger, and machined a whole bunch of the housing out to get the flow going to the wastegate with less resistance (instead of the 90 degree angle). Since then, it has been absolutely perfect!
I definitely wouldn't buy another KKR turbo unless you were planning on doing these modifications, but once done, the turbo is amazing! When i bought it, i got an oil line with it, used that to install it, plugging in to stock oil return line. Water lines were blocked off, and I rearranged stock piping and everything worked fine (i installed a front mount at the same time)
Car was making 220kw with this turbo, limited by stock AFM and injectors. I recently got some S15 injectors and a Z32 and have tuned the car for 250kw at 16psi. I didn't wanna go higher as i don't know how healthy my engine is, but i have seen these turbos doing 300-320kw on other RB25 setups.
Anyway, a friend no longer needs his external gate GT3076 so that's going to me, so i will no longer need this turbo.
We were just re-fibreglassing my front bar yesterday, as the car is going to be painted, so the thin layer of stuff on the turbo is sanded back fibreglass, it doesn't look that old/rusty in person, only on camera for some reason :/
If you have any questions, just ask in this thread so they get answered and everybody can see the answer, or just give me a call on 0421517163 :)
Isaac
https://www.sau.com.au/forums/topic/349254-kkr560-turbo-kit/
