For sale is a alot of exterior panels and interior parts off the HCR32 wreck, other general R32 parts, and other car parts.
Alternatively the series one is for sale as a wreck. $1700 ONO
Please be aware there are no prices on the other items as I am inviting you all to make an offer or simply send me a link to another advert for the same item and i will beat it by 20%.
Parts for sale do not include:
FMIC
Power steering pump
Bonnet
Other whole items for sale include:
1 * cat back exhaust - HKS Dragger - its quite with a deep tone - has two mufflers
1 * electric rad fans - AU falcon - used for 3 months
1 * standard radiator - original HCR32 - a leak at one of the plastic bases mounts, plastic weld should fix it, needs a proper flush too
1 * standard radiator - original BNR32 - no leaks or need for flushing
3 * RS-GT 17x7 wheels - copies bought from aussie tyres - shadow chrome colour- have federal tryes on them worn down to the wear indicators. In my experience the rims clear the rear brake caliper of a GTSt but need a small spacer to clear the front. These may suite a GTSt or any of those 5 stud patterns on Silvias. UNSURE of the offset maybe 35.
1 * RS-GT 17x7 rim - same as above but this one does not have any rubber and it has a damaged outer lip
2 * Side mirrors - genuine - gun grey - LH & RH
1 * Side mirror - genuine - black damaged - RH
1 * Side mirror - genuine - black - LH
1 * front reo bar - genuine - HCR32
1 * Front bumper bar - genuine - HCR32 series II - Gun grey colour - looks a little like a GTR front
Pictures will be posted soon thanks all for reading, buying, or considering buying from this ad. Any questions or enquiries please email me [email protected].
https://www.sau.com.au/forums/topic/349257-r32-parts-and-or-wreck/
  • Replies 84
Posted Images
the advertisement is on facebook as a group, because I am unsure how to edit this ad here on SAU please have a look here http://www.facebook.com/home.php?sk=group_192113467470145&view=doc&id=192113800803445#!/home.php?sk=group_192113467470145&ap=1 for any updates or changes AND for the photos!
thanks people
wiper panel (black panel under windscreen wipers)
rear wiper motor assy.
boot trim
got those?
call me if you do. number in sig.
boot trim
got those?
called and left a message
and PM
FMIC
Power steering pump
Bonnet
DELETE POST
Edited by GTRAAH
how much do you want for the rear guards? (assuming they are in good condition) I will need to cut them off myself as there are certain measurements i will need to take.
cheers
Jason
0430087070
hey mate im after a L/H rear lower control arm, how much posted to 3174.please give me a call on 0411385949 as i dont get on here often. Thanks.
also if anyone else reading this has one for sale feel free to give me a call.
How much you chasing for the interior C-pillar trims? They are the ones the go around that go around the rear quarter window glass on the inside. I need both sides.
Edited by Triptych
cheers
Jason
0430087070
the read guards are fine, and they be worth 20% less than an other advert you find, PM or email the advert and thats a bargin! cheers
cheers
Jason
0430087070
no sorry
yes that interior trim, you can have them for 30% less of the an another advert with the same item.
please email or PM me. ta
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
