  • Replies 84
Posted Images
yeah got them and happy to post them, did you see the photos, they are there?
thank you
sweet sounds good, give me a call on 0451308829 and we can talk about prices and ill give you my address.
Cheers!
Cheers!
sure mate
ill answer you via text message tomorrow morning, ok.
thanks
  • 3 weeks later...
For sale is a alot of exterior panels and interior parts off the HCR32 wreck, other general R32 parts, and other car parts.
Alternatively the series one is for sale as a wreck. $1700 ONO
Please be aware there are no prices on the other items as I am inviting you all to make an offer or simply send me a link to another advert for the same item and i will beat it by 20%.
Parts for sale do not include:
FMIC
Power steering pump
Bonnet
Other whole items for sale include:
1 * cat back exhaust - HKS Dragger - its quite with a deep tone - has two mufflers
1 * electric rad fans - AU falcon - used for 3 months
1 * standard radiator - original HCR32 - a leak at one of the plastic bases mounts, plastic weld should fix it, needs a proper flush too
1 * standard radiator - original BNR32 - no leaks or need for flushing
3 * RS-GT 17x7 wheels - copies bought from aussie tyres - shadow chrome colour- have federal tryes on them worn down to the wear indicators. In my experience the rims clear the rear brake caliper of a GTSt but need a small spacer to clear the front. These may suite a GTSt or any of those 5 stud patterns on Silvias. UNSURE of the offset maybe 35.
1 * RS-GT 17x7 rim - same as above but this one does not have any rubber and it has a damaged outer lip
2 * Side mirrors - genuine - gun grey - LH & RH
1 * Side mirror - genuine - black damaged - RH
1 * Side mirror - genuine - black - LH
1 * front reo bar - genuine - HCR32
1 * Front bumper bar - genuine - HCR32 series II - Gun grey colour - looks a little like a GTR front
Pictures will be posted soon thanks all for reading, buying, or considering buying from this ad. Any questions or enquiries please email me [email protected].
BTW the au fans fit the radiator stock or aftermarket on the GTR's and gtst's
  • 3 weeks later...
FMIC
Power steering pump
Bonnet
2 * BOV - blow off valves HKS works fine for a GTR. it came off a r32 gtr
2 * Tyres - michelin something but has 30% tread with the tread nearer one side wore down
SOLD:
front reo
rear seats
pending HKS dragger exhaust
thanks for the past buyers and to the people considering it
hey man.
im after the boot interior and carpet, the surrounds for the rear quarter window (c pillar i think its called)
and also the stock steering wheel if you have them send us a text 0434879303
Cheers :)
hey mate, you would have stock front and rear suspension?
it not stock suspension, but its lower and legal in QLD. not sure how much lower but leaves the car sitting with a even wheel arch gap.
um KYB struts and king springs.
thanks
hey man.
Cheers :)
Got none of these sorry matey
Hey mate, Im after the RHS climate control bracket, do you still have it? If so would you be able to chuck a pic up? Im happy to get both sides if need be,
Cheers
Edited by k_d
hey mate do you have the switch for the head lights? im also after the gear stick surround (the plastic bit that the leather gator clips into).
shoot us a sms on 0420 767 957 if ya do.
cheers corin
cheers corin
dont have them
Hey mate do you have the rear interior trim I need the part that goes around the back side window on te left and right?
yeh got it ay just the 2 grommets are stuffed
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
