  • Replies 84
Posted Images
  • 3 weeks later...
still sitting here in South Brisbane. Gotta move the car this week or next.
Any offers for the wreck? please let me know asap and I will cut you a good deal
  • 9 months later...
hi everyone, I have been away
thanks for the people who bought so much. and thanks to the guys who concidered it.
I still have parts remaining:
items for sale:
1 * cat back exhaust - RS*R Invidia - has two mufflers suites r32
3 * RS-GT 17x7 wheels - copies bought from aussie tyres - shadow chrome colour- have federal tryes on them worn down to the wear indicators. In my experience the rims clear the rear brake caliper of a GTSt but need a small spacer to clear the front. These may suite a GTSt or any of those 5 stud patterns on Silvias, I would assure you if you had a r32 gtS it would be fine. UNSURE of the offset maybe 35.
1 * RS-GT 17x7 rim - same as above but this one does not have any rubber and it has a damaged outer lip
2 * Side mirrors - genuine - gun grey - LH & RH suites r32
1 * Side mirror - genuine - black damaged - RH suites r32
1 * Side mirror - genuine - black - LH suites r32
2 * Air Filters - HKS - green foam type - came off a stock gtr afm
1 * Turbo Timer - HKS - excellent working condition
1 * Air Box - Genuine - Nissan r32 gtst box without an air filter
  • 4 weeks later...
UPDATED
items for sale:
2 * Radiators - from gtr r32 would suite skylines, and it may suite the silvia
1 * Twin Plate Clutch and lighten flywheel - HKS - GTR Push Type clutch, used and removed because it started to slip. good for custom rebuilding to your liking. Out of R32 gtr.
1 * Turbo Crossover Piping - genuine - From r32 gtr and polished with 'twin turbo' embedded
cheers
Hi mate where u located? keen on zorst and the hkss filter? how much for zorst.. where u located
I am in Burleigh Heads in the Gold Coast
And I am not sure what I I'll let the exhaust go for, say $300.
Air filters would be $120
  • 3 weeks later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
