im sure its the other way around i.e. early model doesnt have the plastic which goes out to the spokes & the later model plastic follows the 3 spokes
unless my 89 gtr & my aust delivered 91 gtr both had late model wheels as both had the plastic backing around the boss which didnt go out to the spokes...can anyone confirm?
  • Replies 57
  • 9 months later...
this is mine on a early model car, although the wheel was bought 2nd hand of ebay, it does have plastic spoke at the back, not sure if that qualifies for an early or late model but i do have hicas light coming on after 10mins or so
ok, this is another pic i found thats different in few respects to the one i posted above, there are more screws around the centre hole and the slots are positioned at 11 and 5 whereas the above one is positioned 12 and 6, no plastic spokes either
alright, can confirm with 99% accuracy that all wheels with slots at 12 and 6 with plastic spokes are latter models and all early model wheels with 11 and 5 are without plastic spokes, so far, i have found latter model wheels listed on cars dated 1992 november
thats means my early model car has an latter model steering wheel installed, hence the hicas light, swap anyone?? :P
Edited by BWRGTR
My 1989 was the opposite (black covered spokes on the rear), unless the wheel I got with it was its second. In any case, it has the plastic covered boss wheel now which is mint, it's lighter anyway.
  • 7 months later...
Just about to do this.
Have a late 92 GTR.
Issue I think I have is that I have BOSS kit for an aftermarket steering wheel.
I haven't taken it off yet but
Question: Will it still have one of these or will I need to buy one ? and if so which one as there is 2 different types :(
Steering wheel looks like this one below (late or early model ?)
and I have a Hicas lock bar fitted (light comes on frequently) so I will disconnect the small plug - yeah ?
Still a bit concerned that once I take off the boss I'll be missing this :(
The white plastic hicas clock spring thingy
Richard,
This is the steering wheel position sensor, you don't need or want to remove this. You posted a picture further up in this thread of a steering wheel, and a steering wheel colum. (white gauge cluster in the background) Is this your car??
If so, all you need to do is remove the horn button from the steering wheel, connect the plug (which is for the horn), ensure front wheels are straight, and put steering wheel on straight. Apply washer, tighten up nut which holds steering in place. Apply horn, done. I recommend applying a little grease or CRC/WD-40 to the tapered part of the steering wheel to aid in getting the steering wheel off a bit easier in future.
Is there any reason why you think that the steering wheel will not go straight on?? It looks like it will to me if the pics above are of your car.
Hi Scott- no thats not my GTR.
That's some earlier in the thread but was used to illustrait for my questions.
Mine actually has a BOSS kit on it.
I'll try get some pics this weekend after i remove the aftermarket steering wheel.
I figure the person who put the BOSS kit on removed the Hicas clock spring (in white in the pics).
Maybe he didn't. Wont know till I pull it apart to check.
Was being lazy. I didn't want to undo the 15 or so allen key bolts to find out I need the thing above in the pic.
Cheers
R
My bad, the pics posted above of the steering wheel and colum were from BWRGTR.
When you pull off your steering wheel boss, the steering wheel sensor should still be in place, mine was. The reason a HICAS boss is used, is so that the steering wheel sensor still works with an aftermarket steering wheel.
Good luck
Edited by Waxhead
for those keen on thier R32 GTR. Up for sale for the next hour is this. On Import Monster.
Looks to be $300 or less deliverd to your door.
Steering Wheel
Damn it, if I didn't have a full credit card I need to pay off and rego on the 32 due I would so buy this
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
