  • Replies 108
V8SkylineMAN wonders if he would look out of place in the gf's festiva.......
yeah probably would.......i really have to go get my line from mackay :D
might come down for a look tho would like to meet some of u guys
Well good news is that we got $45.60 in donations from the meet to go to SAU. Bad news is that I had a bit of a bingle with an island.
Basically end of a really long straight, came in too hot, didnt see the corner coming up but saw the warning sign, started to brake and saw that corner was fast approaching, felt the car back end drift a bit to the left, corrected and then the brakes locked, and pulled up just about 2 metres too far :D
BIG Thanks to all who helped change the tyre and expert opinions on if it was drivable and what needed to be replaced and who joined the train following me basically 95% of the way home.
Think I'll be a passenger for the next couple of cruises:D
Condolences Ska
Hope your downtime is minimal.
Bright side is you were not injured, and just think....it coulda been a wall/ditch/tree/edge of cliff, and done a shitload more damage to you and your car.
Oh hell yeah! I saw the island and aimed fot the middle, no way was I going to try to miss it and hit either end with those signs, that would have been far worse. I did try letting up on the brakes to try to go left, but when I did car seemed to move faster towards the island, brain took over i think and pressed harder :D
Lesson, when you do not know the road, take it easy :D there were a lot of really deceiving corners, I just happen to be the unlucky sod to pay for being a bit too overconfident. Lucky there was no one in front or too close behind me.
Wonder what it looked like from behind, strutto?
Downtime will be long, but only have myself to blame for that :(
yeah you were lucky alright :(~ hunt around for some with with a 33 f/c to grab some bits off ;P sure that it wont cost you much,
i also think if you ask some people they will give you a hand to change it , *raises hand*
any way . good night . even tho my poor widdle frakinstine s13 was a little out of place * i have skyline breaks ;) *
`josh ( povo s13 )
No way your little Sylvia SX Was awesome, was very cool seeing the flames :(
Yeah right at this point in time I dont want to even think about fixing it, I want to sleep, but cant. It's getting very annoying ;)
Dont you worry, as soon as I get a guestamite on the costs and scrounge it from somewhere, I'll be putting the call out for help :D
Thanks a lot for offereing, and again THANKS to all who helped out.
You know the thing that scared me the most was not the crash, it was the hissing once I stopped, I so thought it was the motor and shat myself, turned it all off, and realised it was the tyre deflating, whew, looked underneath, no leaking fluids, whew, I count my lucky stars as 1 metre either way i would have hit those sign poles, nasty even though I only hit it at ~60kph I thought I did pretty good in pulling her up, really tried to keep her straight, and so tried to let off the brakes when it did lock, cause i knew i had to, just brain took over i think.
Oh well, it was an exciting experience :D
Thanks again to all who helped!!!
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
