I have a r32 4door gtst (rb20det) and some times you give it a boot full then go to pull up and the rpm drops off some times to the point were it stalls or you could be drive along and go to change gears and it's like the car stalls out and also it dose it why just putting around anyone got any iders that could help me out even if you could SMS me as I don't really get on here much (0401 787 770)
https://www.sau.com.au/forums/topic/349300-revs-droping/
Have you got an BOV venting to atmosphere? This could be causing the issue if the car is not tuned/tuned correctly.
Also new spark plugs and coilpacks are a good idea, however they are not going to solve your problem of revs dropping and stalling as these are at low load points where you dont require a strong spark. I dont think that will be the issue but its something worth updating anyway.
Clean the AFM and AAC valves and post up if you have an Atmo BOV and if so which one.
Also if you DONT have an atmo bov, and the car has a factory ECU (with no chip, piggyback etc) then perhaps try resetting the ECU. I had my skyline go funny back when it was on stock ECU after I put an atmo BOV on it then took it back off. It did the same thing kept stalling even with the stock BOV back on, and I tried everything and the only thing that fixed it was resetting the ECU
If you want to do that, disconnect the battery and hold your foot on the brakes for about 10 seconds or so then plug the battery back in. But do this only if your sure its the factory ECU with no mods/chips/tunes/piggybacks etc
Edited by 89CAL
https://www.sau.com.au/forums/topic/349300-revs-droping/#findComment-5615062
It is runing the factory ecu but it's been chiped far as I no coz it dose not have speed cut and revs out more and it has a hks ssqv type1 bov.... I will list the mods done to the car witch most of them was already done to the car when I got it
(rb20det)
hks ssqv
hks front mount
turbosmart boost T
hks pod filter
2.5" twin champer dump pipe
3" exhuast
r33 turbo that has been high flowed and has a garrat gt35
ballbearing
Other then that it's standed
it made 232hp on 10psi soon to be going on the dyno after I do me new plugs and coilpacks and biger fuel pump
https://www.sau.com.au/forums/topic/349300-revs-droping/#findComment-5615486
mine didnt have speed cut and seemed to rev more, but trust me it was definently a stock ECU. Yours is running a high flow but making 173rwkw, which suggests its probably still a standard ECU but I'm not going to say it definently is or definently isnt.
If you can, start the car and when its hunting or trying to stall try placing something over the BOV so no air can escape from it. If this makes your revs settle down then I'd say the BOV will be the issue. HKS make plumback kits for the SSQV's (not sure for which generation they apply to but)
https://www.sau.com.au/forums/topic/349300-revs-droping/#findComment-5615707
  • 1 month later...
Hi im am having the same problem when i accelerate to red line then take my foot off the accelerator the car drops and the whole engine shakes.
I have stock ecu,turbo,fmic,turbo exhaust.
i took my car to be diagnosed today but couldn't find the problem. The fuel pump,air flow meter,cas, has been checked and still having same problem..........
I'm sick of wasting time and money can anyone help.
Edited by fly333
https://www.sau.com.au/forums/topic/349300-revs-droping/#findComment-5675377
Revs dropping to the point of stalling...I had the same issue with my r32 gtst. Did a diagnostic with my connect cable n ecutalk software. Turned out to be a code 12 (maf sensor) fault. Cleaned out the afm (sensor & the plug, undid 4 screws n pulled the plug out, sprayed inside with carby/tb cleaner) and it fixed my issue. The contact points inside the plug were bogged up...
https://www.sau.com.au/forums/topic/349300-revs-droping/#findComment-5675964
can someone explain why a rb with no bov will stall more?
Has been covered a million times, air flow is pushed back through the IC pipework (no bov to release pressure), hits the AFM on it's way out of the pod... AFM read's twice the amount of air, chucks in more fuel, stallage.
Doesn't happen to all rb's. there are many people on this forum that don't run bov's and don't have stalling issues.
https://www.sau.com.au/forums/topic/349300-revs-droping/#findComment-5685779
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
    • I used to love stock take. I used to take f**k of a lot of stock. /Rodney Rude.
