As in title im putting up my r33 for sale
2 months ago i picked up a u13 jap import sr20det awd bluebird
and now have no use for 2 turbo cars
Rather sell this car and use it on a deposit for a new home than have it sitting in my garage not being used
Note : This car may not be to everyones taste, hence refrain from posting up negative comments
1993 Model
RB25DET
5 SPEED MANUAL GEARBOX
APPROX 200,000KS ON CLUSTER THOUGH THIS CLUSTER HAS BEEN CHANGED THROUGHOUT ITS LIFE (CAN SHOW EVIDENCE UPON INSPECTION)
ENGINE BAY IS STOCK
HICAS STEERING
AIR CON WORKS PERFECTLY
3 INCH TURBOBACK EXHUAST WITH GOLD HURRICANE MUFFLER
TEIN COILOVERS
ADJUSTABLE CASTER RODS
CAR HAS BEEN RESPRAYED IN BLUE (SIMILAR TO MAZDA 3)
19 INCH BSA WHEELS (HIGH QUALITY AME MODELART REPLICAS, THOUGH 1 PIECE)
245/35/19 DUNLOP SPORTMAXX ON REAR
215/35/19 NANKANG NS2 ON FRONTS
DVD HEADUNIT
ALPINE 4 CHANNEL AMP
PIONEER SPLITS
6000K HID KIT
GTR STYLE FIBREGLASS FRONT BAR (HAS QUIET A BIT OF DAMAGE)
R33 SERIES 2 FRONT BAR (NOT FITTED, AND IS BLACK)
REGO TILL APRIL
SINCE IVE OWNED THE CAR I HAVE FIXED MANY LITTLE PROBLEMS AS FOLLOWING:
REPLACED POWER WINDOW RELAYS AND SWITCHES
GASSED A/C
FIXED SUNROOF
REPLACED STEERING RACK (PREVIOUS ONE LEAKING)
REFURBISHED HEADLIGHTS
NEW BATTERY
NOT INCLUDED WITH THE SALE BUT CAN INCLUDE AT A NEGOTIATED EXTRA PRICE
ARE:
FMIC WITH ALL PIPING
TURBOSMART BOV
CUSTOM NUMBER PLATES : RWD 53X (REAR WHEEL DRIVE SEX)
PRICE IS $9,000 As it is
$10,000 with series 2 front bar fitted and painted
Will consider TRADE INS, but will only give a trade in value etc for your car, so you would be better of selling yours before buying mine, but if you dont want the hassle let me know what you have and ill give you a ballpark figure of how much $$$ ill take of my price.
Car is in great condition and have not had any real problems so far.
there are a few scratches in paint due to idiots bumping there door into the car etc but nothing major. The car has never been boosted in my ownership and seems like has never been boosted prior previous owners. Only reason this car is on the market is that i have no use for it and would rather use the money towards a deposit in purchasing a property, which wont be for atleast another 6 months. So at this stage no rush to get rid of the car.
https://www.sau.com.au/forums/topic/349306-r33-gtst-turbo/
  • 4 months later...
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
  • 4 months later...
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
