Z31 Gearbox Good Condition $300 (want it gone make an offer)S15 Engine 105,000km with everything excluding turbo, fuel injectors and turbo $1,250 (out of car already)
R33 Series 2 Front Calipers with DS2500 pads and 4000DBA discs used only a number of times. $600 (still on car)
6 piston Caliper 336mm rotor WP Pro Brake setup used for 2,000km brade new discs and pads $1200
Work CR KAI Bronze 17x9 +17 set of 2 $700 (Perfect Offset on S13/14/15 front)
Work CR KAI Bronze 18x8.5 +32 set of 2 $500 (one rim damage will have it fixed)
Work CR KAI Bronze 18x9.5 +38 set of 2 $800 (Great Offset on S15 rear)
Semi Slicks R18/265/35 Medium Compound D03G 65% $400 set of 2
Semi Slicks R17/235/45 Medium Compound D03G 40% $300 set of 2
OK condition rear bar $100
1 extra S15 Intake Manifold $100
1 set of urethane engine mounts (used for 2,000km) $80
2 no. S15 standard Exhaust Manifold $100 each
1 no. set n/a SR20 standard cams $150
1 no. Standard S15 throttle body $100
1 no. additional set of Standard S15 Coilpacks $100
All of this needs to go please make an offer.
PM me or call/text me 0428 153 256
Near Ipswich QLD
https://www.sau.com.au/forums/topic/349319-garage-clean-out/
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
